[QGIS-Developer] QGIS Unexpectedly Crashing
Catania, Luke A ERDC-RDE-GRL-VA CIV Luke.A.Catania at erdc.dren.mil
Mon Aug 26 09:42:09 PDT 2024
Oddly while pyqtgraph is pip installed and used in other parts of the pluign, it is not used in any part of this UI, so wondering how it is being referenced.
-----Original Message-----
Sent: Sunday, August 25, 2024 6:31 PM
To: Catania, Luke A ERDC-RDE-GRL-VA CIV <Luke.A.Catania at erdc.dren.mil>
Cc: qgis-developer <qgis-developer at lists.osgeo.org>
Subject: Re: [QGIS-Developer] QGIS Unexpectedly Crashing
On Sun, 25 Aug 2024 at 12:51, Catania, Luke A ERDC-RDE-GRL-VA CIV via QGIS-Developer <qgis-developer at lists.osgeo.org> wrote:
> What causes an access violation intermittently?  Once it happens sometimes it continues to happen, and I have to delete the QGIS directory in AppData\Roaming\ which is annoying because I have my plugin there and I need to copy it to another directory and then copy it back after running QGIS for first time to have the directory recreated.
> It seems to be happening with pyqtgraph\Qt.py which is not my code.
My guess: You've installed pyqtgraph via pip or some binary wheel, and it's using a different Qt library vs what QGIS is bundled with.
Nyall
More information about the QGIS-Developer mailing list
