[QGIS-Developer] pre-commit for code-formatting
Julien Cabieces julien.cabieces at oslandia.com
Thu Dec 12 05:22:54 PST 2024
> HI Julien,
> Thanks for the feedback !
> Le jeu. 12 déc. 2024 à 13:52, Julien Cabieces <julien.cabieces at oslandia.com> a écrit :
>  Hi Denis,
>  Thanks for this work, it works like a charm!
>  Could you add some instructions on how to use it and set it up correctly
>  in the developer guide ?
> This is already published in https://docs.qgis.org/3.40/en/docs/developers_guide/git.html#procedure
> Let me know if this needs to be improved.
Oh, yes, I was looking at an old version of the documentation.
>  I think it's a great tool on developer side but I have my concerns about
>  the CI part. It adds a lot of automatic commit which doesn't help when
>  you want to read the git history. If you want to blame a specific line
>  of code, you can land in this type of commit instead of the relevant
>  modification you were heading to. You can trace it back to the pull
>  request but it's one more step, and it makes us even more attached to the
>  GitHub platform.
> Thanks to Nyall's hint, I have added the refactoring commits to https://github.com/qgis/QGIS/blob/master/.git-blame-ignore-revs
> When I blame files online in Github it seems to be working:
> For instance, https://github.com/qgis/QGIS/blame/master/src/gui/actions/qgsactionmenu.h
> Last commit is the pre-commit run but you don't see it in the blame.
This works for the refactoring commits but not for all the pre-commit
commits added in Pull Requests.
> But I have not done this job in the release-3_40 branch (in which I manually backported).
> More generally I am not super happy about clang-format being more painful to play with our SIP macros but it's much easier than having
> to build a dedicated tool. And having everything in a pre-commit config is much more convenient and clearer/cleaner.
> Best wishes,
> Denis
Julien Cabieces
Senior Developer at Oslandia
More information about the QGIS-Developer mailing list
