[QGIS-Developer] pre-commit for code-formatting
    Denis Rouzaud
    denis.rouzaud at gmail.com
    Thu Dec 12 11:41:01 PST 2024
I would argue in favor of the auto update:
* it's easier for newcomers: having a pull request rejected because of
indentation is not welcoming
* it's easier for online editing
* the argument that you need to rebase is not valid to me:
    * you can always force push and the code beautifier will be run on top
again
    * the solution you mention is to have an environment properly set up:
if you do so, you won't have pre-commit commits in the log
Le jeu. 12 déc. 2024 à 16:53, Jean Felder via QGIS-Developer <
qgis-developer at lists.osgeo.org> a écrit :
> Le 12/12/2024 à 16:38, Even Rouault via QGIS-Developer a écrit :
> > Le 12/12/2024 à 16:33, Julien Cabieces via QGIS-Developer a écrit :
> >> Not a great fan of this approach, It looks like complicated to me, I
> would prefer the old behavior.
> >> Those automatic PR force also contributor to rebase before pushing new
> >> modification to their branch. And if they have modified area of code
> >> which have been reformatted, they get conflicts.
> >> automatic pre-commit commits brings more difficulties than what it
> >> solves IMHO.
> > I also tend to agree on that. On other projects I'm involved too
> > (GDAL, PROJ, shapelib, libtiff) where we have put in place pre-commit,
> > we just have a CI check that checks the formatting is OK. This
> > requires a bit of education to first time contributors, but pointing
> > to the documentation with clear instructions on how to setup
> > pre-commit should be good enough.
> https://github.com/qgis/QGIS/edit/master/.github/PULL_REQUEST_TEMPLATE.md
> > could also have some words about it
> > Like in
> https://github.com/OSGeo/gdal/edit/master/.github/PULL_REQUEST_TEMPLATE.md
> > , " - [ ] Make sure code is correctly formatted (cf [pre-commit
> > configuration](
> https://gdal.org/development/dev_practices.html#commit-hooks))"
> On second thoughts, I agree with Julien and Even.
> Jean
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20241212/0ecf985e/attachment.htm>
