[QGIS-Developer] QGIS 3.46 builds to use Qt6?
Even Rouault even.rouault at spatialys.com
Tue Dec 17 05:56:43 PST 2024
I also believe verisonning Qt6 QGIS builds as 4.0 is the right thing to
do for clarity and from a semantic versioning point of view. This is a
major API break from plugin perspective.  We don't necessarily need to
deal with removal of deprecated APIs at that time . That can be
postponed for a QGIS 5.0. Version numbers are cheap ;-)
Related to that debate, years ago I wanted to call GDAL 2.5 what has
finally been released as GDAL 3.0. From a GDAL perspective, the only
difference between 2.4 and 2.5/3.0 was the PROJ 6 dependency and the
mundane change that CRS were now authority axis aware by default. I
don't regret the 2->3 bump because it turned to be a major change for
users, and the bump was a clear sign they had to do something.
Le 17/12/2024 à 09:17, Nyall Dawson via QGIS-Developer a écrit :
> On Tue, 17 Dec 2024 at 18:00, Julien Cabieces
> <julien.cabieces at oslandia.com> wrote:
>> Hi,
>> I'm also in favor of switching to Qt 6 builds and the timeline you
>> propose Martin seems reasonnable to me.
>> However, I think we should increment the QGIS major version to 4.0 in order
>> to stongly advertise our users and plugin developers that there is an
>> API break. If we are not doing now, when do we plan to increment the
>> major and clean the code from all deprecated content?
> I'm SO strongly against breaking QGIS API unless we ABSOLUTELY have
> to. The pain of the 3.0 transition is still relatively fresh in my
> memory, and I think we would be doing our users and end user
> organisations a great disservice by moving to QGIS 4.0 now.
> I think a 4.0 API bump should be an absolute last resort, when we have
> no other option.
>> Regarding the proposal of having 2 versions (Qt 5 and Qt 6), I'm not
>> completely sure this is a good idea. I'm afraid that plugin developer
>> would delay the plugin migration if this is still possible to run a QGIS
>> with Qt 5.
> Well, that's entirely their choice. But I'd imagine end user pressure
> would result in the majority of frequently used plugins being upgraded
> quite quickly. And if a particular plugin ISN'T compatible with the QT
> 6 builds, then the user who requires that plugin could still run the
> Qt 5 build for the foreseeable future.
>>   It would also be
>> interesting to display on the plugins platform which are compatible with
>> Qt 6 and which are not.
> Definitely -- that would help users make informed decisions as to
> which is the best choice for them.
> Nyall
>> Regards,
>> Julien
>>> On Tue, 17 Dec 2024 at 10:48, Greg Troxel via QGIS-Developer <qgis-developer at lists.osgeo.org> wrote:
>>>> I wonder about "less stable" qt5 and "more stable" qt6.  Do we really
>>>> believe that qgis built on qt6, with no plugins will have fewer crashes
>>>> and quirks, than the qt5 build?
>>> Yes, I do. Because Qt 5 is not improving any more, but Qt 6 is. An example would be when running under Wayland environments on
>>> linux -- it's a very broken mess on Qt 5 and will never be fixed. On Qt 6 it's only a slightly-broken mess, and will likely be non-broken within
>>> the next 12 months. There's a similar situation for apple processors, which never had full official support on Qt 5 but ARE fully supported
>>> on Qt 6. This gap is only getting wider as newer operating system updates and corresponding changes break things underneath Qt 5.
>>> There's also a limited stream of bug fixes getting ported back to Qt 5.15, vs those flowing into the supported Qt 6 releases.
>>>>   That is surprising to me at this point.
>>>> Do we still believe that if one assumes "qgis with N random plugins that
>>>> claim to support qt6"?
>>> (Well, QGIS + **ANY** plugin = a less stable QGIS. 🤣 But that's a completely different point)
>>>> I expect a qt6 build is kind of like a .0 release, and we would want to
>>>> have qt6 builds widel avaialable and time for feedback before saying
>>>> it's stable.
>>> I'd say we're well past the ".0" stage of Qt 6 support. Almost all the core functionality is quite well tested at this stage, and third party
>>> clients (like Mergin and QField) switched to Qt 6 based QGIS builds earlier this year. I'm confident that by the time we hit a (potential)
>>> October 2025 milestone that we'll have a very stable Qt 6 build available.
>>> Nyall
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Julien Cabieces
>> Senior Developer at Oslandia
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
More information about the QGIS-Developer mailing list
