[QGIS-Developer] Warning: auto-transaction groups is broken for recent GDAL versions
Nyall Dawson
nyall.dawson at gmail.com
Tue Dec 17 15:48:46 PST 2024
On Wed, 18 Dec 2024 at 03:23, Alessandro Pasotti via QGIS-Developer
<qgis-developer at lists.osgeo.org> wrote:
> Hi Andreas,
> I spoke briefly to Even and we agreed that I could use the QGIS funds to work on a GDAL implementation initially limited to SQLite-based drivers.
> I don't have a cost estimate yet but I will have a look before the end of the year.
Ok great, I've updated the PR to just disable the test for GDAL >= 3.5
now. It can be conditionally resurrected when there's a fix in GDAL.
Nyall
> Thanks for the proposal.
> Il mar 17 dic 2024, 08:53 Andreas Neumann <andreas at qgis.org> ha scritto:
>> Hi,
>> If we can find a developer who could work on this then we can fund it directly from QGIS.ORG.
>> We had so far quite a bit more income than expenses in 2024 and I am looking for meaningful ways to spend additional QGIS funds.
>> Thanks,
>> Andreas
>> On Tue, 17 Dec 2024 at 08:40, Alessandro Pasotti via QGIS-Developer <qgis-developer at lists.osgeo.org> wrote:
>>> Can/should we fix it upstream in GDAL?
>>> On Tue, Dec 17, 2024 at 2:12 AM Even Rouault via QGIS-Developer <qgis-developer at lists.osgeo.org> wrote:
>>>> It is *partly* broken, that is if you change the structure of tables by
>>>> adding/altering/removing columns. within a transaction group. If
>>>> adding/updating/deleting features only, which I suspect covers most use
>>>> cases, that should be fine.
>>>> Le 17/12/2024 à 00:11, Nyall Dawson via QGIS-Developer a écrit :
>>>> > Hi list,
>>>> > Just want to draw attention to
>>>> > https://github.com/qgis/QGIS/pull/59797#issuecomment-2544133498 . In
>>>> > short, the "auto transaction group" functionality is BROKEN when used
>>>> > with sqlite/geopackage files when used with newer GDAL versions.
>>>> > This IS NOT a GDAL issue, but rather just a "happy accident" that this
>>>> > functionality ever worked (QGIS is misusing GDAL API for this
>>>> > feature).
>>>> > There's a non-trivial amount of work to do in refactoring this feature
>>>> > to get it working again. If you're interested in seeing this
>>>> > functionality fixed, please read the above linked thread for all the
>>>> > diagnostic work that Even and myself have already done and hints on
>>>> > how it could possibly be fixed.
>>>> > Accordingly, in https://github.com/qgis/QGIS/pull/59910 I propose to
>>>> > disable the corresponding test, which is currently blocking upgrading
>>>> > CI infrastructure to newer Ubuntu/Fedora releases.
>>>> > Nyall
>>>> > _______________________________________________
>>>> > QGIS-Developer mailing list
>>>> > QGIS-Developer at lists.osgeo.org
>>>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> http://www.spatialys.com
>>>> My software is free, but my time generally not.
>>>> Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
>>> Alessandro Pasotti
>>> QCooperative: www.qcooperative.net
>>> ItOpen: www.itopen.it
>> Andreas Neumann
>> QGIS.ORG board member (treasurer)
