[QGIS-Developer] Delete references to a plug-in in the qgis3.ini file on uninstallation
Johannes Kröger (WhereGroup) johannes.kroeger at wheregroup.com
Fri Feb 23 01:26:31 PST 2024
Hi!
If the plugin did not clean up itself then you will have to clean up
manually. Plugins can edit anything anywhere in that file. If you are
concerned about changes to the file, then best place it under version
control.
Cheers, Hannes
On 23.02.24 10:10, Jesus García Villar via QGIS-Developer wrote:
> Hi everyone,
> When uninstalling a plugin it keeps leaving me configuration
> parameters inside the *Qgis3.ini* file located at the following address.
> C:\UsersUARIO\AppData\Roaming\QGIS\QGIS3\profiles\default\QGIS\QGIS\
> How to delete all references to a plugin once it is uninstalled?
> Gracias
> SERVIGIS
> Jesús García Villar
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
Johannes Kröger / GIS-Entwickler/-Berater
FOSSGIS Konferenz
20.-23. März 2024 in Hamburg
https://www.fossgis-konferenz.de/2024/
WhereGroup-Beiträge auf der FOSSGIS
https://wheregroup.com/unternehmen/aktuelles/
WhereGroup GmbH
c/o KK03 GmbH
Lange Reihe 29
20099 Hamburg
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240223/0ef2d33e/attachment-0001.htm>
More information about the QGIS-Developer mailing list
