[QGIS-Developer] Compiling against homebuilt GDAL
Even Rouault
even.rouault at spatialys.com
Wed Feb 28 10:45:52 PST 2024
Thomas,
Le 28/02/2024 à 19:33, Thomas Larsen Wessel via QGIS-Developer a écrit :
> I have successfully built QGIS and GDAL (3.7.2) separately. Now I want
> to build QGIS against this GDAL. This is what I tried:
> git clone git at github.com:qgis/QGIS.git
> cd QGIS
> mkdir build
> cd build
> GDAL_DIR=/home/velle/gdal3.7.2/build cmake ..
> The output contains the following error for GDAL:
> CMake Error at /home/velle/gdal-3.7.2/build/GDALConfig.cmake:24 (include):
> include could not find requested file:
> /home/velle/gdal-3.7.2/build/GDAL-targets.cmake
> Call Stack (most recent call first):
> cmake/FindGDAL.cmake:16 (find_package)
> CMakeLists.txt:365 (find_package)
> Could someone please tell me if I'm even doing it right?
You need to *install* GDAL first. You can't just point QGIS to the GDAL
build directory
So in the GDAL build directory, do "cmake ..
-DCMAKE_INSTALL_PREFIX=$HOME/install-gdal-3.7.2 ; make -j$(nproc); make
install"
and then when configuring QGIS, use GDAL_DIR=$HOME/install-gdal-3.7.2 .
I'm not totally sure about that last part. may require tweaking. you
could alter the PATH to point to $HOME/install-gdal-3.7.2/bin so that
"gdal-config" from your installed GDAL is picked up
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240228/9f63bcd5/attachment.htm>
