[QGIS-Developer] Signals and QtDesigner
Jorge Tornero
jtorlistas at gmail.com
Thu Feb 29 14:37:25 PST 2024
Thanks Nyall!!!
El jue, 29 feb 2024 a las 22:01, Nyall Dawson (<nyall.dawson at gmail.com>)
escribió:
> On Fri, 1 Mar 2024, 5:02 am Jorge Tornero via QGIS-Developer, <
> qgis-developer at lists.osgeo.org> wrote:
>> Hello all,
>> I write the list because I have a a simple question (currently I'm trying
>> to tackle issue #56275 Improve Parsing of Data from Serial Port Sensors).
>> Is using the QtDesigner signal/slot assignment facilities discouraged?
>> I've read this in the QGIS coding standards guide and don't really know if
>> that means that:
>> *Avoid use of Qt auto connect slots (i.e. those named void
>> on_mSpinBox_valueChanged).*
>> So, If I need to connect two widgets in a groupBox (a radioButton and a
>> QLineEdit, just to enable the QLineEdit only a determinate radioButton is
>> selected), should I make it programatically instead using QtDesigner?
> I realise you posted a follow up, but just to confirm -- yes, do NOT rely
> on connections made in the designer.
> The rationale is that the designer can break these connections without any
> warning. Eg if you cut and paste some widgets to move them around, any
> connections to those will be silently broken. It's much safer to rely on
> manual connections with compile time checks...
> Nyall
>> Thanks a lot
>> Jorge
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240229/f688fc12/attachment.htm>
