[QGIS-Developer] Plugin python library installation
Benjamin Chartier - Pro contact at bchartier.net
Wed Jan 3 09:13:35 PST 2024
I created a simple QGIS plugin in order to install non standard Python
modules in QGIS:
https://github.com/bchartier/gecosat-gms-python-modules-installer
It is not supposed to work on any other OS than Windows. I created it
for one a my client which only uses Windows.
The list of Python modules to be installed is there:
https://github.com/bchartier/gecosat-gms-python-modules-installer/blob/main/gms_install_python_modules/config/requirements.txt
This is experimental. I hope this could help.
Regards,
Benjamin
Le 15/11/2023 à 21:00, qgis-developer-request at lists.osgeo.org a écrit :
> Message: 1
> Date: Wed, 15 Nov 2023 09:40:31 +0100
> From: Giacomo Titti<giacomotitti at gmail.com>
> To:qgis-developer at lists.osgeo.org
> Subject: [QGIS-Developer] Plugin python library installation
> Message-ID:
> 	<CAO7kFnFgR19x221Vg2bz9FpdRd6qJCLX4pXE5b1RHQivCv7MiQ at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Hi all,
> I would install python libraries when the plugin that I'm developing Is
> installed.
> I read something about the possibility to list the required libraries in
> the metadati.txt but I don't think there Is not an installer already
> available in QGIS for the libraries, Am I correct? Is there any way to do
> so? Has someone a code example for a solution?
> I'm trying to run a subprocess to install libraries via PIP but I think It
> Is not the proper way to do so.
> Thanks
> Best
> Giacomo
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL:<http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231115/b812c594/attachment-0001.htm>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240103/aa04ad9a/attachment.htm>
More information about the QGIS-Developer mailing list
