[QGIS-Developer] Loading netCDF4 seems to crash QGISv3.34
afernandez
afernandez at odyhpc.com
Mon Jan 8 07:30:14 PST 2024
Hello QGIS Developers,
This problem still persists with v3.34 and it's easily reproducible by simply opening the python console and typing:
import netCDF4 as nc
I opened a new ticket QGIS crashes when importing netCDF4 · Issue #55787 · qgis/QGIS (github.com) <https://github.com/qgis/QGIS/issues/55787> . In the meantime, I'll also try installing v3.32 and checking whether the crash also happens or not.
Thank you.
afernandez via QGIS-Developer wrote:
Hello,
I'm upgrading from v3.30 to 3.34. However, QGISv3.34 keeps crashing when trying to import the netCDF4 module (never had this issue with v3.30). More specifically, the log reads:
Fatal Python error: Segmentation fault
Current thread 0x0000ffff7dada020 (most recent call first):
File "<frozen importlib._bootstrap>", line 241 in _call_with_frames_removed
File "<frozen importlib._bootstrap_external>", line 1184 in exec_module
File "<frozen importlib._bootstrap>", line 688 in _load_unlocked
File "<frozen importlib._bootstrap>", line 1006 in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 1027 in _find_and_load
File "/opt/atrium/QGIS/build-master/output/python/qgis/utils.py", line 888 in _import
File "/home/ubuntu/.local/lib/python3.10/site-packages/netCDF4/__init__.py", line 3 in <module>
File "<frozen importlib._bootstrap_external>", line 883 in exec_module
File "/home/ubuntu/.local/share/QGIS/QGIS3/profiles/default/python/plugins/TABULA/plugin/pingere.py", line 11 in <module>
File "/home/ubuntu/.local/share/QGIS/QGIS3/profiles/default/python/plugins/TABULA/plugin/mainPlugin.py", line 12 in <module>
File "/home/ubuntu/.local/share/QGIS/QGIS3/profiles/default/python/plugins/TABULA/__init__.py", line 13 in classFactory
File "/opt/atrium/QGIS/build-master/output/python/qgis/utils.py", line 423 in _startPlugin
File "/opt/atrium/QGIS/build-master/output/python/qgis/utils.py", line 443 in startPlugin
File "<string>", line 1 in <module>
Extension modules: PyQt5.QtCore, PyQt5.QtGui, PyQt5.QtWidgets, PyQt5.QtPrintSupport, PyQt5.Qsci, PyQt5.QtNetwork, PyQt5.QtMultimedia, PyQt5.QtXml, PyQt5.QtPositioning, PyQt5.QtSql, qgis._core, qgis._gui, netCDF4._netCDF4, numpy.core._multiarray_umath, numpy.core._multiarray_tests, numpy.linalg.lapack_lite, numpy.linalg._umath_linalg, numpy.fft._pocketfft_internal, numpy.random._common, numpy.random.bit_generator, numpy.random._bounded_integers, numpy.random._mt19937, numpy.random.mtrand, numpy.random._philox, numpy.random._pcg64, numpy.random._sfc64, numpy.random._generator, cftime._cftime (total: 28)
and the referenced line reads import netCDF4 as nc. I've tried 2 different plugins but both crash QGIS. Just for completeness, netCDF4 had previously installed:
$ Successfully installed cftime-1.6.3 netCDF4-1.6.5
Thanks and happy New Year.
Hello,
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240108/fb4af60f/attachment.htm>
