[QGIS-Developer] Changing attributes of a newly created feature in Python form init code
Johannes Kröger (WhereGroup)
johannes.kroeger at wheregroup.com
Wed Jan 10 01:48:24 PST 2024
Still stumped with this, now cross-posted to
https://gis.stackexchange.com/questions/474014/changing-attributes-of-a-newly-created-feature-in-python-form-init-code
I noticed that the both the `id(feature)` is always different when I
look at it in either function which suggests the object got copied (by
the `partial()` call?). The same is true for `feature.id()`. As a hack I
tried using a global instead of passing the feature to `on_ok()`.
[insert confused emoji here]
Probably I am blind to something really basic.
Cheers, Hannes
On 04.01.24 16:47, Johannes Kröger (WhereGroup) via QGIS-Developer wrote:
> Hey guys,
> I feel really dumb and I guess I am missing some basic concept...:
> * I have a layer with two attributes: "text" (string) and "int"
> (integer).
> * I used drag'n'drop form design to have a form with just the "text"
> attribute in it.
> * I added Python Init Code:
> from functools import partial
> def on_ok(layer, feature):
> field_idx = layer.fields().indexOf("int")
> attribute_changed = layer.changeAttributeValue(feature.id(),
> field_idx, 12345)
> if not attribute_changed:
> raise Exception("Attribute value could not be changed!")
> def my_form_open(dialog, layer, feature):
> ok_button = dialog.findChild(QPushButton)
> ok_button.clicked.connect(partial(on_ok, layer, feature))
> So the form does not show an input widget for the "int" field. But
> when pressing OK, the code should change the edited feature's "int"
> value to 12345.
> This works if I edit existing features.
> But if I create a new feature, the "int" value will be empty/NULL
> instead of 12345.
> Any pointers on how to properly update a new feature's attribute
> fields, that exist on a layer but are not shown the user with the
> QGIS' widgets in the attribute form?
> Cheers, Hannes
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240110/781a5cbc/attachment.htm>
