[QGIS-Developer] Running unit tests without "make install"
Sandro Santilli
strk at kbt.io
Tue Jan 16 09:14:45 PST 2024
On Mon, Jan 15, 2024 at 10:28:19PM +0100, Thomas Larsen Wessel via QGIS-Developer wrote:
> Thanks for having a look at it :) I ran a complete test and saved the test
> output to this gist. Is that what you were looking for? Please tell me what
> other info you need.
> https://gist.github.com/velle/b195bee9a5d63e95ea7aa600b7833be1
May I suggest to file a ticket for each of those failures ?
Thee's a "testsuite" label that can be used for them, at the moment
there are 13 open tickets with that label, but only a few are failures
in tests:
https://github.com/qgis/qgis/issues?q=is%3Aopen+is%3Aissue+label%3Atestsuite
Having them all will hopefully help improving the ability of
developers to run those tests successfully.
--strk;
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240116/2a03db5a/attachment.sig>
