[QGIS-Developer] plugins: pip dependecies
Matthias Kuhn
matthias at opengis.ch
Fri Jan 26 02:43:44 PST 2024
Hi Martin,
You might try qpip, it's designed for exactly this purpose:
https://github.com/opengisch/qpip
Kind regards
Matthias
On Fri, Jan 26, 2024 at 11:38 AM Alessandro Pasotti via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hi Martin,
> plugin dependencies are for plugin dependent on other plugins, it has
> nothing to do with python packages.
> See:
> https://docs.qgis.org/3.28/en/docs/pyqgis_developer_cookbook/plugins/plugins.html#metadata-txt
> On Fri, Jan 26, 2024 at 11:29 AM Martin Landa via QGIS-Developer <
>> Hi,
>> I would like to ask regarding QGIS plugin publishing which has pip
>> dependency.
>> In metadata.txt I added:
>> plugin_dependencies=smoderp2d
>> When trying to install a plugin from ZIP created by pb_tool unfortunately
>> smoderp2d dependency is not installed. The Plugin Dependencies Manager is
>> shown, the dialog just hangs with Action -> Fix manually. No error message
>> is displayed.
>> [image: image.png]
>> How can I fix this issue? Thanks in advance for your help. Regards, Martin
>> PS: I tried to install smodep2d manually by pip and it worked fine.
>> Martin Landa
>> http://geo.fsv.cvut.cz/gwiki/Landa
>> http://gismentors.cz/mentors/landa
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alessandro Pasotti
> QCooperative: www.qcooperative.net
> ItOpen: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240126/2df31b81/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240126/2df31b81/attachment-0001.png>
