[QGIS-Developer] Python regression in the latest patch release 3.34.3
Johannes Kröger (WhereGroup)
johannes.kroeger at wheregroup.com
Wed Jan 31 00:38:36 PST 2024
Hi Lauri,
have you considered using the python-qgis.bat/python-qgis-ltr.bat
instead? That should set all PATHs etc correctly.
Cheers, Hannes
On 31.01.24 08:57, Lauri Kajan via QGIS-Developer wrote:
> Hi all,
> This might be more of an OSGeo4W issue, but I wanted to bring it to
> your attention.
> Unfortunately, something has changed in the latest patch release
> 3.34.3 on Windows regarding Python.
> The logic of how Python finds its DLLs has changed somehow. I know
> that Python has upgraded to 3.9.18 to get necessary security updates.
> We have relied on the process where we create a virtual environment
> for plugin development. We have previously created it with command
> `C:\Program Files\QGIS 3.34.3\apps\Python39\python.exe -m venv
> --system-site-packages .venv`
> We have then set the needed module lookup path with a `pth`-file and
> dll paths with the `sitecustomize.py` in the virtual environment.
> This has worked great previously but now fails.
> The first error I got is that `zlib.dll` was not found. This can be
> “fixed” by copying it to `C:\Program Files\QGIS 3.34.3\apps\Python39`
> (which I would prefer not to do since our training clients don’t
> necessarily have permissions for that on their computers).
> The second problem comes when `pip` is tried to be installed to the
> venv by `ensurepip`. This step fails because python.exe won’t find its
> `python39.dll`.
> The venv can be created with `--without-pip` flag but after activating
> the vevn and calling python.exe, it also fails to start and gives an
> error `python39.dll` is not found. How come python.exe can't find the
> DLL file from `apps\Python39` which is correctly set as `home` in the
> `pyvenv.cfg`?
> If the `C:\Program Files\QGIS 3.34.3\apps\Python39` folder is added to
> `PATH`, then python39.dll can be found. This is also a step I would
> prefer not to be necessary.
> Is this something that was expected in the Python upgrade?
> Has this changed in Python itself or has something changed in OSGeo4W
> packaging?
> Is it expected that the previous mode of operation will be restored?
> Does anyone have any ideas on how to overcome this?
> Regards,
> Lauri
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Johannes Kröger / GIS-Entwickler/-Berater
Aufwind durch Wissen!
Web-Seminare und Online-Schulungen
bei der www.foss-academy.com
WhereGroup GmbH
c/o KK03 GmbH
Lange Reihe 29
20099 Hamburg
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
