[QGIS-Developer] Transition from QtWebKit to QtWebEngine in qgis2web (QGIS plugin)
info at opengis.it
info at opengis.it
Tue Jul 9 08:46:39 PDT 2024
Thanks Jan Dalheimer
Thanks Jean-Baptiste Peter
From your answers I understood many things.
I tried both to use QGIS 3.38.0 installed in win10 via .msi and the version via OSGeo4W setup; In the first case I added qtwebengine via "pip install qtwebengine", in the second case I installed the "python3-pyqtwebengine" package via OsGeo4w setup
In both installations I get the same result: QtWebEngine it does not work well
I also tried to create a new test plugin and I get the same result, I can't even view a web page. Is there an example of a basic plugin that I can see? Or can someone create it?
The clue:
If I use qt designer to insert a QtWebEngineView into the plugin graphics it works well, even when setting a static web page.
But if I open QGIS that plugin won't work, why does this happen? I would therefore think that it is just a question of dependency .
For now I noticed this:
1) From QGIS version 3.38.0 I can use "from qgis.PyQt.QtWebEngineWidgets import *" instead of "from PyQt5.QtWebEngineWidgets import *"
2) with qgis 3.38.0 .msi installation this dependency is missing:
qt5-devel (5.15.13-1)
Qt5 headers and libraries (Development)
Required by: python3-pyqtwebengine
3) with OSGeo4W setup these dependencies are required:
python3-core (3.12.4-1)
Python core interpreter and runtime
Required by: python3-pyqtwebengine, python3-pyqt5, python3-pyqt5-sip
python3-pyqt5 (5.15.10-1)
Python bindings for the Qt cross platform application toolkit
python3-pyqt5-sip (12.13.0-1)
The sip module support for PyQt5
qt5-libs (5.15.13-1)
Qt5 runtime libraries
Required by: python3-pyqtwebengine, python3-pyqt5, qt5-devel, qtwebkit-libs
Thank you all
Andrea Ordonselli
OpenGIS.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240709/581f6e5f/attachment.htm>
