[QGIS-Developer] UX of Raster Legend in the QGIS Layers Panel
Niklas Alt niklas.alt at uni-marburg.de
Fri Jun 7 00:05:04 PDT 2024
Dear QGIS Developers,
I am a long time user, first time subscriber to this list. I am active
though for some years within the local
OSGeo Chapter of Germany FOSSGIS (and the QGIS user group), so some
people on the list might be able
to put a face on this message.
I am always expressing my gratitude to the QGIS dev-community in
personal, so let me start with a big thank you.
I have been using QGIS for the last 10 years and our community has come
a long way.
Now to my issue: A few versions back QGIS has started to expand raster
files with a legend, once they are
added to the layer-panel. We are working mostly with georeferenced
historical maps, so for the most part
the maps are simple RGB files with transparency. And often we add dozens
of maps which make up a city.
Leading to long lists of expanded legends informing about the fact that
all maps are made up of RGB color bands.
Additionaly we are relying on the opacity slider, which can be added to
the layer tree, allowing for a convenient
way to control the opacity of the added maps. However the slider is only
visible when the map is expanded in the layer-panel.
I have posted a while back on mastodon and have added some images for
illustrative purposes:
https://fedihum.org/@oshistory/111821429135997460
Perhaps the following alterations might be considered for an improved UX:
  - new raster layers are collapsed by default (users who need to
inspect the legend can toggle it)
  - users can decided if they want the legend to  be displayed. This
could for instance be set within the Legend
    Tab of the Layer Properties panel. In fact, there already is an
option to use a placeholder, maybe a simple boolean
    checkbox could serve as a graphical control item
  - maybe the legend and other UI Elements (like the mentioned opacity
slider) could be seperated.
Best Wishes,
Niklas Alt, Marburg, Germany
Niklas Alt  Wiss. MA. Hessisches Institut für Landesgeschichte
Wilhelm-Röpke-Str. 6C 35032 Marburg fon +49 (0)6421 28-91759 fax -24799
Hinweise zur Verarbeitung Ihrer personenbezogenen Daten finden Sie unterhttps://hlgl.hessen.de/datenschutzhinweise
More information about the QGIS-Developer mailing list
