[QGIS-Developer] Compiling against homebuilt GDAL
Thomas Larsen Wessel mrvelle at gmail.com
Tue Mar 12 03:44:57 PDT 2024
Sorry for the late reply.
@Richard; Your advice is certainly useful. I could use some advice on best
practices :)
After *installing* GDAL, I was able to run cmake without issues. But then
make would fail at 56% every time (simply printing "Error 2"). By
coincidence I found out, that if I just ran the same make command one more
time (without cleaning), it would progress beyond the 56%, and run for
another 20 minutes before it failed at 64%. If I ran for a third time it
would progress a bit more (or maybe the output just looks different), but
still at 64%. Any additional attempts give no further progress.
mkdir build; cd build
GDAL_DIR=/home/velle/install-gdal-3.7.2 cmake .. -DCMAKE_BUILD_TYPE=DEBUG
2>&1 | tee cmakelog.txt
time make -j4 VERBOSE=1 2>&1 | tee make_j4_1.txt
time make -j4 VERBOSE=1 2>&1 | tee make_j4_2.txt
time make -j4 VERBOSE=1 2>&1 | tee make_j4_3.txt
The last part of make_j4_3.txt looks like this:
Dependencies file
"src/core/CMakeFiles/qgis_core.dir/vectortile/qgsvtpktiles.cpp.o.d" is
newer than depends file
"/home/velle/b/QGIS/build/src/core/CMakeFiles/qgis_core.dir/compiler_depend.internal".
Dependencies file
"src/core/CMakeFiles/qgis_core.dir/vectortile/qgsvtpkvectortiledataprovider.cpp.o.d"
is newer than depends file
Dependencies file
"src/core/CMakeFiles/qgis_core.dir/vectortile/qgsxyzvectortiledataprovider.cpp.o.d"
Consolidate compiler generated dependencies of target qgis_core
make[2]: Leaving directory '/home/velle/b/QGIS/build'
make  -f src/core/CMakeFiles/qgis_core.dir/build.make
make[2]: Entering directory '/home/velle/b/QGIS/build'
make[2]: Nothing to be done for 'src/core/CMakeFiles/qgis_core.dir/build'.
[ 64%] Built target qgis_core
make[1]: Leaving directory '/home/velle/b/QGIS/build'
make: *** [Makefile:166: all] Error 2
I don't see anything failing until the point it aborts. Can I get more
details about what is failing?
It took some time to find the VERBOSE=1 option, but even with verbose
output I don't understand what is going on. Is it
On Thu, Feb 29, 2024 at 8:52 AM Matthias Kuhn <matthias at opengis.ch> wrote:
> On Wed, Feb 28, 2024 at 7:45 PM Even Rouault via QGIS-Developer <
> qgis-developer at lists.osgeo.org> wrote:
>> and then when configuring QGIS, use GDAL_DIR=$HOME/install-gdal-3.7.2  .
>> I'm not totally sure about that last part. may require tweaking. you could
>> alter the PATH to point to $HOME/install-gdal-3.7.2/bin so that
>> "gdal-config" from your installed GDAL is picked up
> It will first try to locate GDAL via cmake config (
> https://github.com/qgis/QGIS/blob/master/cmake/FindGDAL.cmake#L16). Only
> if that fails it will fall back to the gdal-config executable.
> To help cmake find a package on a custom install prefix, refer to
> https://cmake.org/cmake/help/latest/command/find_package.html#config-mode-search-procedure
> in your case I'd suggest using `-D GDAL_ROOT=$HOME/install-gdal-3.7.2`
> after installing
> Matthias
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240312/2a85a0ff/attachment.htm>
More information about the QGIS-Developer mailing list
