[QGIS-Developer] Hardware Considerations for QGIS Specialists
Matthias Kuhn
matthias at opengis.ch
Mon Mar 18 03:15:04 PDT 2024
Hi Adam,
Both, Ram and CPU, play an important role and you will see better
performance results. Which of the two is more important heavily depends on
the particular use case.
The graphics card on the other hand is currently only used for very
specific needs. It would be possible to further enhance this support, but
this would need investment into the software.
Hope this helps
Kind regards
Matthias
On Mon, Mar 18, 2024 at 10:55 AM aday8300 via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Dear Subscribers,
> How does QGIS leverage the computational resources of a computer system,
> particularly in terms of:
> · CPU cores (main / main and additional) – Does investing in the
> number and types of cores significantly impact QGIS performance, especially
> when the user will be utilizing QGIS for professional analysis?
> · Cores and RAM – How does QGIS utilize both cores and RAM, and
> is there a recommended balance between them for optimal performance in
> professional analysis tasks?
> · RAM alone – Does increasing RAM capacity alone enhance QGIS
> performance, particularly when used for professional analysis?
> · CPU with the utilization of RAM on the graphics card – How does
> the choice of a graphics card with sufficient RAM impact QGIS performance,
> considering the CPU's utilization of it, especially in the context of
> Thank you in advance for your assistance.
> Best regards, Adam Więcko
> FKE Ekoprobono
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240318/d50fe286/attachment-0001.htm>
