[QGIS-Developer] Qt WebEngine in QGIS 3.36
Enzo Cocca
enzo.ccc at gmail.com
Sun May 26 02:24:45 PDT 2024
Sorry
Like that
from qgs.PyQt.QtWebEngineWidgets import QWebEngineView, QWebEnginePage
from qgis.PyQt.QtCore import QCoreApplication, QObject
from qgis.PyQt.QtWidgets import QAction
from qgis.core import QgsApplication
from qgis.gui import QgsMapCanvas
Il dom 26 mag 2024, 11:17 Enzo Cocca <enzo.ccc at gmail.com> ha scritto:
> Hi Enrico, have you tried to import early the qwebengine before the other
> modules?
> Like that example:
> from PyQt5.QtWebEngineWidgets import QWebEngineView, QWebEnginePage
> class MyPlugin(QObject):
> def __init__(self, iface):
> super().__init__()
> self.iface = iface
> self.web_view = QWebEngineView()
> self.web_view.setPage(QWebEnginePage())
> self.initGui()
> I fixed the same problem in this way but I use windows not Linux
> Best
> E
> Il dom 26 mag 2024, 10:42 Enrico Ferreguti via QGIS-Developer <
> qgis-developer at lists.osgeo.org> ha scritto:
>> Dear QGIS developers, I would need your support to update my plugins.
>> I read that Qt WebEngine, from QGIS
>> 3.36.3-Maidenhead, QT 5.15.3, is available for plugins:
>> https://changelog.qgis.org/en/entry/2607
>> But on Ubuntu Jammy LTS 22.04 and a fresh QGIS 3.36.3-Maidenhead with QT
>> 5.15.3, when I try to import from QT5:
>> from PyQt5.QtWebEngineWidgets import QWebEngineView, QWebEnginePage,
>> I get an exception:
>> ImportError: QtWebEngineWidgets must be imported before a
>> QCoreApplication instance is created
>> and when I do the same from python3 in bash I get no exceptions
>> Where Am I wrong? Is there something different to do for importing
>> QtWebEngineWidgets ?
>> Can you point me to a running example?
>> Thank you very much.
>> Enrico Ferreguti
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240526/be5ebbf2/attachment.htm>
