[QGIS-Developer] QGIS Full Stack Web Developer Report
    Lova Andriarimalala
    lova at kartoza.com
    Tue Nov 12 22:00:56 PST 2024
Hello Julien,
Thanks for your reply.
> It's not clear to me what are the criteria to have a website's feed
referenced. Is featured content only in English or other languages are
accepted? Other criteria?
For the time being, the separate Planet website has the same workflow as
the current website at https://plugins.qgis.org/planet/ (except for
switching to a static website). The posts are fetched from each
subscriber’s feed link (
https://github.com/Xpirix/QGIS-Planet-Website/blob/main/data/subscribers.json)
without any filtering. The subscribers.json file serves as the primary
entry point, so the feed link should be included there to display on the
Planet website.
Most of the posts are in English, but since there’s no language filter,
there are a few posts in other languages.
> To filter on "QGIS" stuff only, do the planet support RSS items category
to?
Yes, it supports item categories, which are translated as tags. We could
primarily base the filter on them (only items with QGIS in the category).
If QGIS isn’t present in the category, we could check the post title and
then the content when fetching the feeds.
Best regards,
Lova Andriarimalala
*QGIS Full Stack Developer   *
*T *: +27(0) 87 809 2702          *E *: lova at kartoza.com          *W* :
kartoza.com
*This email and any attachments are confidential and intended solely for
the use of the individual or entity to whom they are addressed. If you *
*have received this email in error, please notify the sender immediately
and delete it from your system. Unauthorised use, disclosure, or copying*
*of the contents is prohibited.*
On Tue, 12 Nov 2024 at 22:20, Julien Moura (Oslandia) via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hello Lova,
> Still a pleasure to read your good work.
> To follow up on my previous email, we would greatly appreciate your input
> on filtering posts specifically on the new Planet Website to only
> QGIS-related content. Many posts are not related to QGIS.
> to?
> Regards,
> Julien
> Le 08/11/2024 à 14:09, Lova Andriarimalala via QGIS-Developer a écrit :
> Hello everyone,
> This week, I concentrated on resolving most of the issues and taking into
> account the feedback provided on the separated plugins, resources hub, and
> planet website. All the pull requests on the new repositories were merged
> and deployed as preview versions.
>    - Plugins: https://staging.plugins.qgis.org, repo is at
>    https://github.com/Xpirix/QGIS-Plugins-Website
>    - Hub: http://hub.qgis/ (require VPN for now), repo is at
>    https://github.com/Xpirix/QGIS-Hub-Website
>    - Planet: https://xpirix.github.io/QGIS-Planet-Website/, repo is at
> We always welcome any new feedback on these updated sites.
> The next steps would be to plan the migration of the separated websites
> and then integrate the issues and pull requests from the QGIS-Django
> repository into the new repositories. I will also try to work on other QGIS
> websites.
> Have a nice weekend,
> Best regards,
> Lova Andriarimalala
> kartoza.com
> On Fri, 25 Oct 2024 at 15:52, Lova Andriarimalala <lova at kartoza.com>
> wrote:
>> Hello everyone,
>> This week, I focused on updating the branding of the Planet website using
>> the Hugo framework, building on the work previously done on the QGIS.org
>> site.
>>    - You can preview the updated version at:
>>    https://xpirix.github.io/QGIS-Planet-Website/.
>>    - I encourage you to check it out and share any feedback or
>>    suggestions at https://github.com/Xpirix/QGIS-Planet-Website/issues.
>> We would also like your input on filtering posts specifically related to
>> QGIS for the new Planet website. This could be accomplished through the
>> content, titles, or tags.
>> Additionally, I have updated the preview of the plugins' website at
>> https://staging.plugins.qgis.org based on feedback from the community
>> and the PSC.
>> Have a nice weekend.
>> Lova Andriarimalala
>> kartoza.com
>> On Fri, 18 Oct 2024 at 15:35, Lova Andriarimalala <lova at kartoza.com>
>> wrote:
>>> Hello everyone,
>>> For the last two weeks, I mainly focused on continuing the branding
>>> update for the plugins' and the resources hub website. Please find below
>>> the links to the PRs:
>>>    - Plugins: https://github.com/Xpirix/QGIS-Plugins-Website/pull/5
>>>    - Hub resources: https://github.com/Xpirix/QGIS-Hub-Website/pull/5
>>> I have also updated the preview of the plugins' website at
>>> https://staging.plugins.qgis.org.
>>> Next week, I will concentrate on updating the branding of the Planet
>>> website using the Hugo framework and implementing some fixes on the plugins
>>> and the hub resources based on the feedback received.
>>> Lova Andriarimalala
>>> kartoza.com
>>> On Fri, 4 Oct 2024 at 17:00, Lova Andriarimalala <lova at kartoza.com>
>>> wrote:
>>>> Hey everyone,
>>>> This week, I've been working on updating the branding for the plugins'
>>>> website and addressing some issues on the main website. Here's a summary of
>>>> what I've been up to:
>>>> *Plugins' website UI branding update: - You can check out a preview of
>>>> the updated plugins' website at https://staging.plugins.qgis.org
>>>> <https://staging.plugins.qgis.org> - I've opened a pull request related to
>>>> this update at https://github.com/Xpirix/QGIS-Plugins-Website/pull/5
>>>> <https://github.com/Xpirix/QGIS-Plugins-Website/pull/5> - Please take a
>>>> look and share your feedback or suggestions on the PR regarding the updated
>>>> UI for the Plugins website. *
>>>> *New PRs on the QGIS' main website:*
>>>>    - Improvement for development version roadmap
>>>>    <https://github.com/qgis/QGIS-Website/pull/449>
>>>>    - Remove unused png inside static/img
>>>>    <https://github.com/qgis/QGIS-Website/pull/450>
>>>>    - Update instructions for macOs installation
>>>>    <https://github.com/qgis/QGIS-Website/pull/453>
>>>>    - Task to update news bar
>>>>    <https://github.com/qgis/QGIS-Website/pull/454>
>>>> Best regards,
>>>> Lova Andriarimalala
>>>>  : kartoza.com
>>>> for the use of the individual or entity to whom they are addressed. If you *
>>>> immediately and delete it from your system. Unauthorised use, disclosure,
>>>> or copying*
>>>> On Fri, 27 Sept 2024 at 16:07, Lova Andriarimalala <lova at kartoza.com>
>>>> wrote:
>>>>> Hello everyone,
>>>>> Please find below the last two weeks' report regarding the maintenance
>>>>> and development of the QGIS main and related websites:
>>>>> *Merged and new PRs on QGIS.org:*
>>>>>    - Fix fetch_feeds script, add image resizing process
>>>>>    <https://github.com/qgis/QGIS-Website/pull/438>
>>>>>    - Add donors scraping CGI scripts
>>>>>    <https://github.com/qgis/QGIS-Website/pull/442> (with ongoing
>>>>>    discussion)
>>>>> *New PR on the changelog website:*
>>>>>    - Optimize nginx and uwsgi for generating certificates
>>>>>    <https://github.com/kartoza/prj.app/pull/1469>
>>>>> *Ongoing task:*
>>>>>    - Update site branding to match feed.qgis.org
>>>>>    <https://github.com/qgis/QGIS-Django/issues/319>, the draft PR is
>>>>>    available at https://github.com/Xpirix/QGIS-Plugins-Website/pull/5
>>>>> Best regards,
>>>>> Lova Andriarimalala
>>>>>  : kartoza.com
>>>>> or copying*
>>>>> On Fri, 20 Sept 2024 at 13:16, Lova Andriarimalala <lova at kartoza.com>
>>>>> wrote:
>>>>>> Hello everyone,
>>>>>> maintenance and development of the QGIS main and related websites:
>>>>>> *Deployed PRs on QGIS.org:*
>>>>>>    - Add students with certificates pictures to certification
>>>>>>    programme page <https://github.com/qgis/QGIS-Website/pull/436>
>>>>>>    - Update the edit layers on the homepage to be accurate
>>>>>>    <https://github.com/qgis/QGIS-Website/pull/429>
>>>>>>    - Show the country instead of dates in the members list
>>>>>>    <https://github.com/qgis/QGIS-Website/pull/428>
>>>>>>    - Create qugsnews.atom
>>>>>>    <https://github.com/qgis/QGIS-Website/pull/437>
>>>>>>    - Script to update donors list from text files
>>>>>>    <https://github.com/qgis/QGIS-Website/pull/440>
>>>>>>    - Add a meetings link to the navigation bar
>>>>>>    <https://github.com/qgis/qgis-uni-navigation/pull/12>
>>>>>>    - Decrease the menu right position when hidden on mobile
>>>>>>    <https://github.com/qgis/qgis-uni-navigation/pull/17>
>>>>>> *New PRs on plugins.qgis.org <http://plugins.qgis.org>:*
>>>>>>    - Feedback resubmission fix
>>>>>>    <https://github.com/qgis/QGIS-Django/pull/464>
>>>>>>    - Fix plugin version edit
>>>>>>    <https://github.com/qgis/QGIS-Django/pull/466>
>>>>>>    - Hub dependency field
>>>>>>    <https://github.com/qgis/QGIS-Django/pull/470>
>>>>>>    - Resource Hub API <https://github.com/qgis/QGIS-Django/pull/471>
>>>>>> Next week, I will continue working on some of the issues on the main
>>>>>> (QGIS.org) and changelog websites (
>>>>>> https://github.com/kartoza/prj.app/issues).
>>>>>> Best regards,
>>>>>> Lova Andriarimalala
>>>>>>  : kartoza.com
>>>>>> or copying*
>>>>>> On Fri, 30 Aug 2024 at 15:14, Lova Andriarimalala <lova at kartoza.com>
>>>>>> wrote:
>>>>>>> Hello everyone,
>>>>>>> Please find below the report for this week's maintenance and
>>>>>>> development of the QGIS and related websites:
>>>>>>> This week, I focused on updating the branding of the plugin's
>>>>>>> website to match the current QGIS.org and Feed. Please find my progress at
>>>>>>> https://github.com/Xpirix/QGIS-Plugins-Website/pull/5.
>>>>>>> These changes are based on the issue QGIS-Django #319
>>>>>>> <https://github.com/qgis/QGIS-Django/issues/319> and are split into
>>>>>>> smaller issues at
>>>>>>> https://github.com/Xpirix/QGIS-Plugins-Website/issues.
>>>>>>> Next week, I will continue working on this update and probably do
>>>>>>> some maintenance tasks.
>>>>>>> Best regards,
>>>>>>> Lova Andriarimalala
>>>>>>> *W* : kartoza.com
>>>>>>> or copying*
>>>>>>> On Fri, 23 Aug 2024 at 15:49, Lova Andriarimalala <lova at kartoza.com>
>>>>>>> wrote:
>>>>>>>> Hello everyone,
>>>>>>>> *Overview:*
>>>>>>>> I mainly focused on splitting the website of the plugin into 3
>>>>>>>> parts which are: plugins, planet and the resource hub.
>>>>>>>> *Ongoing task:*
>>>>>>>> I have set new repos on my GH account for the plugin website,
>>>>>>>> planet website and resource hub. :
>>>>>>>>    - Resources hub: https://github.com/Xpirix/QGIS-Hub-Website
>>>>>>>>    - Planet: https://github.com/Xpirix/QGIS-Planet-Website
>>>>>>>> For the Planet website, I tried to match the branding with the
>>>>>>>> QGIS.org website using Bulma, React and Django Rest Framework. Please feel
>>>>>>>> free to check the progress at:
>>>>>>>> https://github.com/Xpirix/QGIS-Planet-Website/pull/4
>>>>>>>> *Deployed PRs on the QGIS Website:*
>>>>>>>>    - Replace QGIS 3.38 docs links with QGIS testing
>>>>>>>>    <https://github.com/qgis/QGIS-Website/pull/395>
>>>>>>>>    - Add issues report links for plugins, feed, changelog
>>>>>>>>    <https://github.com/qgis/QGIS-Website/pull/412>
>>>>>>>>    - Fix language name
>>>>>>>>    <https://github.com/qgis/QGIS-Website/pull/398>
>>>>>>>>    - Remove inexistent roadmap page
>>>>>>>>    <https://github.com/qgis/QGIS-Website/pull/397>
>>>>>>>>    - Use latest for docs links in get involved and thank you pages
>>>>>>>>    <https://github.com/qgis/QGIS-Website/pull/404>
>>>>>>>>    - Some fixes for the GH issue template
>>>>>>>>    <https://github.com/qgis/QGIS-Website/pull/405>
>>>>>>>> Best regards,
>>>>>>>> Lova Andriarimalala
>>>>>>>> *W* : kartoza.com
>>>>>>>> solely for the use of the individual or entity to whom they are addressed.
>>>>>>>> If you *
>>>>>>>> or copying*
>>>>>>>> On Fri, 9 Aug 2024 at 16:46, Lova Andriarimalala <lova at kartoza.com>
>>>>>>>> wrote:
>>>>>>>>> Hello everyone,
>>>>>>>>> Please find below this week's report for the maintenance and
>>>>>>>>> *Overview:*
>>>>>>>>> I mainly focused on deploying the latest changes on the QGIS
>>>>>>>>> website, the QGIS Feed Website and the QGIS Plugins Website. I also
>>>>>>>>> worked on some issues for them.
>>>>>>>>> * - Optimise sponsors logo
>>>>>>>>> <https://github.com/qgis/QGIS-Website/pull/388> - Add qgis 1st conference
>>>>>>>>> image to the thank-you page <https://github.com/qgis/QGIS-Website/pull/389>
>>>>>>>>> - Limit roadmap schedule table width to 100%
>>>>>>>>> <https://github.com/qgis/QGIS-Website/pull/396> - Add a select menu to
>>>>>>>>> choose a language for documentation
>>>>>>>>> <https://github.com/qgis/QGIS-Website/pull/391> - Optimise sponsors logo
>>>>>>>>> <https://github.com/qgis/QGIS-Website/pull/388> - Fixes for the playwright
>>>>>>>>> test and the commit hash link
>>>>>>>>> <https://github.com/qgis/QGIS-Website/pull/390> *
>>>>>>>>> *Deployed PRs on the QGIS Plugin Website:*
>>>>>>>>>    - Feedback clarification
>>>>>>>>>    <https://github.com/qgis/QGIS-Django/pull/452>
>>>>>>>>> *Deployed PRs on the QGIS Feed Website:*
>>>>>>>>>    - Allow xx_XX lang in the parameter
>>>>>>>>>    <https://github.com/qgis/qgis-feed/pull/93>
>>>>>>>>>    - Update the design to match the new website
>>>>>>>>>    <https://github.com/qgis/qgis-feed/pull/72>
>>>>>>>>> *New PRs on the QGIS Website:*
>>>>>>>>>    - Fix language name
>>>>>>>>>    - Remove the inexistent roadmap page
>>>>>>>>> *Ongoing task:*
>>>>>>>>>    - Split the website of the plugin to plugins, planet and hub
>>>>>>>>>    <https://github.com/qgis/QGIS-Django/issues/454>
>>>>>>>>> *Question/feedback needed:*
>>>>>>>>> About the licensing for a plugin when uploading it to
>>>>>>>>> plugins.qgis.org, I was wondering if we could allow the COPYING
>>>>>>>>> as a valid license file apart from the LICENSE file. This is related to an
>>>>>>>>> ongoing discussion at
>>>>>>>>> https://github.com/qgis/QGIS-Django/issues/453.
>>>>>>>>> Lova Andriarimalala
>>>>>>>>> *W* : kartoza.com
>>>>>>>>> If you *
>>>>>>>>> or copying*
> QGIS-Developer mailing listQGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Oslandia
> <https://oslandia.com/?utm_source=email&utm_campaign=signature_oslandia&utm_medium=email>
> - Geotribu
> <https://geotribu.fr/?utm_source=email&utm_campaign=signature_oslandia&utm_medium=email>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20241113/c7875f63/attachment-0001.htm>
