[QGIS-Developer] Renaming a plugin directory?
Johannes Kröger (WhereGroup) johannes.kroeger at wheregroup.com
Mon Oct 14 04:34:12 PDT 2024
Hi Lova,
thanks for your swift response!
That's what I expected and what seems very reasonable, considering the
potential for problems. I think we will simply publish a new version of
the old plugin to display a message to our (few) existing users and
create a "new" plugin for the new version.
That should keep surprise factor low and allow a clean cut without any
unforeseen issues.
Are we able to upload a new plugin that uses the same name as the
existing, deprecated one? Or do we have to choose a new name (or a
different name for the old one) first?
Thank you!
Cheers, Hannes
On 11.10.24 15:21, Lova Andriarimalala wrote:
> Dear Hannes,
> At the moment, it's not possible to change a plugin's directory name
> (package_name) even through the administration page.
> This feature was previously requested with a PR, but it was closed due
> to potential client-side issues. When the package_name changes, QGIS
> may recognize the plugin as a new one, leading to possible
> installation errors.
> You can find the related PR and a more detailed discussion about it at
> https://github.com/qgis/QGIS-Django/pull/271.
> However, we are open to new ideas and suggestions on this matter. I
> can also re-check the feature to have an updated detail about it.
> Best regards,
> Lova Andriarimalala
> *QGIS Full Stack Developer
> *T *: +27(0) 87 809 2702 *E *:**lova at kartoza.com *W* : kartoza.com
> <http://kartoza.com>
> /This email and any attachments are confidential and intended solely
> for the use of the individual or entity to whom they are addressed. If
> you /
> /have received this email in error, please notify the sender
> immediately and delete it from your system. Unauthorised use,
> disclosure, or copying/
> /of the contents is prohibited./
> On Fri, 11 Oct 2024 at 14:30, Johannes Kröger (WhereGroup) via
> QGIS-Developer <qgis-developer at lists.osgeo.org> wrote:
>     Hi there!
>     Wonderful people from Oslandia have started collaborating on our
>     experimental (and somewhat buggy) Profile Manager plugin.
>     https://plugins.qgis.org/plugins/profile-manager/
>     https://github.com/WhereGroup/profile-manager/
>     One of the changes was restructuring the repository and using a
>     PEP8-compliant directory name for the plugin's module directory
>     ("profile_manager" instead of "profile-manager").
>     Now the automated CI/CD upload of new releases fails. Presumably
>     because
>     the site expects "profile_manager".
>     https://github.com/WhereGroup/profile-manager/issues/10#issuecomment-2402479699
>     Would it be possible to update that on the plugin's existing Plugins
>     repository entry?
>     I saw
>     https://lists.osgeo.org/pipermail/qgis-developer/2024-May/066744.html
>     but that was only for the user visible name, the plugin's URL and the
>     installed directory name stayed the same.
>     What would it mean for existing users?
>     Would they simply not be notified about new releases, and have to
>     install the "new" plugin manually?
>     Or would something break and require manual intervention, e.g. two
>     version of the plugin being installed and loaded, one in
>     plugins/profile_manager and the old one in plugins/profile-manager?
>     Cheers, Hannes
>     Johannes Kröger / GIS-Entwickler/-Berater
>     Schon gewusst?
>     In unserem Blog geben wir Tipps & Tricks zu Open-Source-GIS-Software
>     und berichten aus laufenden und abgeschlossenen Projekten
>     https://wheregroup.com/blog/
>     WhereGroup GmbH
>     c/o KK03 GmbH
>     Lange Reihe 29
>     20099 Hamburg
>     Germany
>     Tel: +49 (0)228 / 90 90 38 - 36
>     Fax: +49 (0)228 / 90 90 38 - 11
>     www.wheregroup.com <http://www.wheregroup.com>
>     Geschäftsführer:
>     Olaf Knopp, Peter Stamm
>     Amtsgericht Bonn, HRB 9885
>     _______________________________________________
>     QGIS-Developer mailing list
>     QGIS-Developer at lists.osgeo.org
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Schon gewusst?
WhereGroup GmbH
c/o KK03 GmbH
Lange Reihe 29
20099 Hamburg
Germany
www.wheregroup.com
Geschäftsführer:
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20241014/332c8358/attachment-0001.htm>
More information about the QGIS-Developer mailing list
