[QGIS-Developer] Renaming a plugin directory?
Lova Andriarimalala
lova at kartoza.com
Wed Oct 16 06:05:51 PDT 2024
Dear Julien,
Thanks for reporting the issue. I've assigned this issue to myself.
Best regards,
Lova Andriarimalala
*QGIS Full Stack Developer *
*T *: +27(0) 87 809 2702 *E *: lova at kartoza.com *W* :
kartoza.com
*This email and any attachments are confidential and intended solely for
the use of the individual or entity to whom they are addressed. If you *
*have received this email in error, please notify the sender immediately
and delete it from your system. Unauthorised use, disclosure, or copying*
*of the contents is prohibited.*
On Wed, 16 Oct 2024 at 11:06, Julien Moura (Oslandia) via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hi Hannes and Lova,
> Thanks for asking and answering. We will proceed as recommended. It might
> be worth adding a relevant section in the plugins developer documentation
> or cookbook.
> To follow up about the naming convention, as written in
> https://github.com/qgis/QGIS-Django/issues/475 I would suggest to make
> sure that new plugins folders are Python compliant since a plugin is a
> Python package and may be imported by other "Python things" within QGIS.
> Regards,
> Julien
> Le 14/10/2024 à 14:43, Lova Andriarimalala via QGIS-Developer a écrit :
> Dear Hannes,
> Sure, I think that's a great idea.
> I think it's better to rename the old plugin first if you want to keep the
> same name for the new one, as uploading a new plugin with an existing name
> is not allowed. Please, feel free to let me know if you need help with
> this. It's also possible to update the name from the metadata, although
> this option is disabled by default.
> Best regards,
> Lova Andriarimalala
> kartoza.com
> On Mon, 14 Oct 2024 at 14:34, Johannes Kröger (WhereGroup) <
> johannes.kroeger at wheregroup.com> wrote:
>> Hi Lova,
>> thanks for your swift response!
>> That's what I expected and what seems very reasonable, considering the
>> potential for problems. I think we will simply publish a new version of the
>> old plugin to display a message to our (few) existing users and create a
>> "new" plugin for the new version.
>> That should keep surprise factor low and allow a clean cut without any
>> unforeseen issues.
>> Are we able to upload a new plugin that uses the same name as the
>> existing, deprecated one? Or do we have to choose a new name (or a
>> different name for the old one) first?
>> Thank you!
>> Cheers, Hannes
>> On 11.10.24 15:21, Lova Andriarimalala wrote:
>> Dear Hannes,
>> At the moment, it's not possible to change a plugin's directory name
>> (package_name) even through the administration page.
>> This feature was previously requested with a PR, but it was closed due to
>> potential client-side issues. When the package_name changes, QGIS may
>> recognize the plugin as a new one, leading to possible installation errors.
>> You can find the related PR and a more detailed discussion about it at
>> https://github.com/qgis/QGIS-Django/pull/271.
>> However, we are open to new ideas and suggestions on this matter. I can
>> also re-check the feature to have an updated detail about it.
>> Best regards,
>> Lova Andriarimalala
>> kartoza.com
>> On Fri, 11 Oct 2024 at 14:30, Johannes Kröger (WhereGroup) via
>> QGIS-Developer <qgis-developer at lists.osgeo.org> wrote:
>>> Hi there!
>>> Wonderful people from Oslandia have started collaborating on our
>>> experimental (and somewhat buggy) Profile Manager plugin.
>>> https://plugins.qgis.org/plugins/profile-manager/
>>> https://github.com/WhereGroup/profile-manager/
>>> One of the changes was restructuring the repository and using a
>>> PEP8-compliant directory name for the plugin's module directory
>>> ("profile_manager" instead of "profile-manager").
>>> Now the automated CI/CD upload of new releases fails. Presumably because
>>> the site expects "profile_manager".
>>> https://github.com/WhereGroup/profile-manager/issues/10#issuecomment-2402479699
>>> Would it be possible to update that on the plugin's existing Plugins
>>> repository entry?
>>> I saw
>>> https://lists.osgeo.org/pipermail/qgis-developer/2024-May/066744.html
>>> but that was only for the user visible name, the plugin's URL and the
>>> installed directory name stayed the same.
>>> What would it mean for existing users?
>>> Would they simply not be notified about new releases, and have to
>>> install the "new" plugin manually?
>>> Or would something break and require manual intervention, e.g. two
>>> version of the plugin being installed and loaded, one in
>>> plugins/profile_manager and the old one in plugins/profile-manager?
>>> Cheers, Hannes
>>> Johannes Kröger / GIS-Entwickler/-Berater
>>> Schon gewusst?
>>> In unserem Blog geben wir Tipps & Tricks zu Open-Source-GIS-Software
>>> und berichten aus laufenden und abgeschlossenen Projekten
>>> https://wheregroup.com/blog/
>>> WhereGroup GmbH
>>> c/o KK03 GmbH
>>> Lange Reihe 29
>>> 20099 Hamburg
>>> Germany
>>> Tel: +49 (0)228 / 90 90 38 - 36
>>> Fax: +49 (0)228 / 90 90 38 - 11
>>> www.wheregroup.com
>>> Geschäftsführer:
>>> Olaf Knopp, Peter Stamm
>>> Amtsgericht Bonn, HRB 9885
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Schon gewusst?
>> und berichten aus laufenden und abgeschlossenen Projektenhttps://wheregroup.com/blog/
>> WhereGroup GmbH
>> c/o KK03 GmbH
>> Lange Reihe 29
>> 20099 Hamburg
>> Germany
>> johannes.kroeger at wheregroup.comwww.wheregroup.com
>> Geschäftsführer:
> QGIS-Developer mailing listQGIS-Developer at lists.osgeo.org
> Oslandia
> <https://oslandia.com/?utm_source=email&utm_campaign=signature_oslandia&utm_medium=email>
> - Geotribu
> <https://geotribu.fr/?utm_source=email&utm_campaign=signature_oslandia&utm_medium=email>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20241016/e5d153d3/attachment.htm>
