[QGIS-Developer] Is there a recommended GDAL version for QGIS 3.34?
Thomas Larsen Wessel mrvelle at gmail.com
Sat Sep 7 01:36:39 PDT 2024
Could someone please tell me if Im correct in thinking that the unittest on
GitHub, CI for Qt5, will also fail because GDAL v. 3.4.1 updates timestamps
of gpkg files, even when just reading them. And if it does not fail
"checkGitStatus", then why not? What is different between my Ubuntu 22.04
and the Ubuntu 22.04 that runs tests on GitHub?
I have more tests failing locally than just gitCheckStatus, but I chose
this one as the first one to deal with. And I thought compiling against a
more recent version of GDAL was the solution.
If I've gone off track, or completely misunderstood something, then please
give me a hint to get back on track :)
On Tue, Sep 3, 2024 at 9:13 PM Thomas Larsen Wessel <mrvelle at gmail.com>
wrote:
> The instructions on the repo tell me, in rather strict wording, to run the
> unit tests locally before creating a PR.
> The test checkGitStatus keeps failing locally. It does so because GDAL
> updates the timestamp of gpkg files, even when only reading them. The
> Internet told me that I needed to build against GDAL v. 3.4.2 or greater,
> to not have these timestamps updated. So thats what I have spent a few
> evenings trying to do. There are other tests that fail too, but this is the
> one I chose to look at first.
> So it's quite surprising that you tell me CI for Qt5 uses GDAL 3.4.1.
> Wouldn't that cause the automatic online test on github to fail? Or have I
> misunderstood something? :)
> Sincerely, Thomas
> On Tue, Sep 3, 2024 at 8:32 PM Even Rouault via QGIS-Developer <
> qgis-developer at lists.osgeo.org> wrote:
>> For operational uses, I would say the latter is the better. For
>> regression test purposes, some tests might perhaps need tweaking/skipping
>> depending on the GDAL version. CI uses GDAL 3.4.1 for QT5 testing and 3.7.3
>> for QT6 testing.
>> > Background/motivation for asking: I have tried compiling different
>> versions of QGIS against different versions of GDAL, but some unit tests
>> keep causing segmentation faults. Could a segmentation fault be caused by a
>> mismatch of version of a dependent library like GDAL?
>> Nobody can guess that. You need to provide much more details: which
>> test(s), stack trace when it crashes, etc.
>> -- http://www.spatialys.com
>> My software is free, but my time generally not.
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240907/45fdc343/attachment.htm>
More information about the QGIS-Developer mailing list
