[QGIS-Developer] QGIS Documentation Report
Selma Vidimlic selma at kartoza.com
Fri Apr 18 08:44:27 PDT 2025
Hello all,
Here is the new documentation report. It includes previously unreported
pull requests that were completed some time ago, as well as the most recent
updates.
Elevation Filter Update
<https://github.com/qgis/QGIS-Documentation/pull/9610>
Advanced Digitizing - Construction Guides
<https://github.com/qgis/QGIS-Documentation/pull/9582>
Mesh Select All and Mesh Select Isolated Vertices
<https://github.com/qgis/QGIS-Documentation/pull/9660>
Mesh Render Extent Settings
<https://github.com/qgis/QGIS-Documentation/pull/9668>
Layout Updates <https://github.com/qgis/QGIS-Documentation/pull/9707>
Surface to polygon - mesh algorithm
<https://github.com/qgis/QGIS-Documentation/pull/9715>
Processing algorithms - metadata tools
<https://github.com/qgis/QGIS-Documentation/pull/9706>
Elevation profile image algorithm
<https://github.com/qgis/QGIS-Documentation/pull/9726>
Plots - new parameters
<https://github.com/qgis/QGIS-Documentation/pull/9760>
SensorThings new section
<https://github.com/qgis/QGIS-Documentation/pull/9127>
Georeferencer updates <https://github.com/qgis/QGIS-Documentation/pull/9759>
I have moved the Georeferencer section from the Working with Raster Data
chapter to the Managing Data Sources chapter. A pull request for this
change is currently open and may be merged in the meantime.
Lova and I have also started recording our biweekly sprint updates, which
we are publishing on the official QGIS YouTube channel, so you can check
that also.
Video
<https://www.youtube.com/watch?v=9bekJq9tRJU&list=PLi6mvse6ZEOwxd9NjHq7-WnRwfqWqMwUR>
Have a nice weekend,
Best regards.
Selma Vidimlic Husic
*QGIS Documentation writer*
*E:* selma at kartoza.com         * W:* kartoza.com
*This email and any attachments are confidential and intended solely for
the use of the individual or entity to whom they are addressed. If you *
*have received this email in error, please notify the sender immediately
and delete it from your system. Unauthorised use, disclosure, or copying *
*of the contents is prohibited.*
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250418/ab5dce23/attachment.htm>
More information about the QGIS-Developer mailing list
