[QGIS-Developer] qgisMinimumVersion for supportsQt6=True
Richard Duivenvoorde
rdmailings at duif.net
Thu Apr 24 11:13:42 PDT 2025
My take would be 3.40 is new LTR, give our slow updaters some slack and set your minimum to 3.34 (old ltr?) or so?
There was some graph somewhere on what QGIS versions are being used in the wild, and you would not believe the ancient versions still being used :-) (I think it is/was https://analytics.qgis.org but that currently gives a 502 error)
Regards,
On 24-04-2025 16:39, Marco Lechner - FOSSGIS e.V. via QGIS-Developer wrote:
> Hi,
> I already started making my QGIS plugins qt6 compatible. It wasn't complicated - thanks to the given migration and check tools. My code is Qt5/Qt6 compatible now, but I am not sure what will be the qgisMinimumVersion? Which QGIS official packages are usually compiled with which Qt5 and Python versions? I can only check my available installations, which are all 3.40 LTR on either Ubuntu or Windows. I guess a qt5/qt6-compatible Plugin may need at least Qt5.15.x and Python 3.12? Until now my plugins qgisMinimumVersion was 3.4 - should this be edited to 3.40? Ot what may fit best?
> Any recommendations?
> Regards
> Marco
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
