[QGIS-Developer] using the QgsGoogleMapsGeocoder class
Johannes Kröger (WhereGroup)
johannes.kroeger at wheregroup.com
Thu Aug 7 23:57:04 PDT 2025
see
https://qgis.org/pyqgis/master/core/QgsGeocoderContext.html#qgis.core.QgsGeocoderContext
You can use it to define an area of interest and to specify
transformation settings.
I guess this should work:
geocoder_context =
QgsGeocoderContext(QgsProject.instance().transformContext())
geocoder = QgsGoogleMapsGeocoder(apiKey="foo")
for geocoder_result in geocoder.geocodeString("bar", geocoder_context):
print(geocoder_result)
Cheers, Hannes
On 8/7/25 17:05, Guillermo D'Angelo via QGIS-Developer wrote:
> Hi there!
> Does somebody have an example or snippet on how to use the
> "QgsGoogleMapsGeocoder" class from PyQGIS?
> I want to geocode a string using the method "//geocodeString" but I
> don't undestand what is the qgis.core.QgsGeocoderContext class and how
> to use it.
> Thanks a lot.
> Guillermo D'Angelo
> Encargado del Departamento de Geografía
> División de Trabajo de Campo
> Dirección Nacional Transferencias Monetarias y Análisis de Datos
> Av. 18 de julio 1453 | Piso 1
> Tel.: (+598) 2400 0302, int. 1262
> gdangelo at mides.gub.uy <mailto:>
> www.mides.gub.uy <http://www.mides.gub.uy>
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
Johannes Kröger
GIS-Entwickler/-Berater
WhereGroup GmbH
Lange Reihe 29
20099 Hamburg
Germany
Tel: +49 (0)228 / 90 90 38 - 36
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250808/7643a922/attachment.htm>
