[QGIS-Developer] [Qgis-psc] Qt6 status
Alessandro Pasotti apasotti at gmail.com
Fri Aug 22 00:10:09 PDT 2025
I am currently on vacation but I will have a look next week.
Kind regards
Alessandro Pasotti
QCooperative:  www.qcooperative.net
ItOpen:   www.itopen.it
Il gio 21 ago 2025, 11:22 Marco Bernasocchi via QGIS-PSC <
qgis-psc at lists.osgeo.org> ha scritto:
> Thanks Nyall for the work and answer.
> on the other two points,
> - having some solution for the extremely slow sip build times on qt6
> Martin, do you have an ETA for David's grant https://github.com/qgis/QGIS-Enhancement-Proposals/pull/338
> - porting the ogc server ci to qt6
> Alessandro, would that be something you'd be willing/would have time ressources to take over since you worked a lot on the server in the past?
> it would be great if we can move all this forward so we can come closer to a qgis 4.0.
> I'd also would like to re ask if we should start preparing for a 1(x?) month delay for the freeze? And remember that there are funding available.
> Cheers
> Marco
> On Fri, 8 Aug 2025 at 05:22, Nyall Dawson <nyall.dawson at gmail.com> wrote:
>> On Fri, 8 Aug 2025 at 04:11, Marco Bernasocchi <marco at qgis.org> wrote:
>> > Hi all,
>> > I was just pointed to this mail
>> > https://lists.osgeo.org/pipermail/qgis-developer/2025-July/067716.html
>> > and noticed that Nyall mentions some still needed work.
>> > @Nyall, do you think the freeze in 5 weeks is realistic? Do we need to
>> plan/prepare something different?
>> > Please, all developer involved in moving to Qt6, that the psc still has
>> reserved funding for this.
>>  - porting the Ubuntu ci infrastructure to qt6, including the database
>> server based tests
>> I'm currently working on this -- see
>> https://github.com/qgis/QGIS/pull/62809
>> Nyall
>> > Cheers Marco
>> > Marco Bernasocchi
>> > QGIS.org Chair
>> > OSGEO.org VP Europe
>> > OPENGIS.ch CEO
>> > http://berna.io
> Marco Bernasocchi
> QGIS.org Chair
> OSGEO.org VP Europe
> OPENGIS.ch CEO
> http://berna.io
> QGIS-PSC mailing list
> QGIS-PSC at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250822/a0235be5/attachment.htm>
More information about the QGIS-Developer mailing list
