[QGIS-Developer] Request to be added as maintainer of the CDU Creator plugin
Lova Andriarimalala lova at kartoza.com
Mon Aug 25 04:22:11 PDT 2025
Dear Manuele,
I would suggest kindly asking the original plugin's author first to (1) add
you as a collaborator and (2) set you as a maintainer from the edit page:
https://plugins.qgis.org/plugins/<plugin_package_name>/update/. Otherwise,
a confirmation from the original author or at least the organisation is
required.
Best regards,
Lova Andriarimalala
*QGIS Full Stack Developer   *
*T *: +27(0) 87 809 2702          *E *: lova at kartoza.com          *W* :
kartoza.com
*This email and any attachments are confidential and intended solely for
the use of the individual or entity to whom they are addressed. If you *
*have received this email in error, please notify the sender immediately
and delete it from your system. Unauthorised use, disclosure, or copying*
*of the contents is prohibited.*
On Mon, 25 Aug 2025 at 10:41, Manuele Pesenti via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Sorry, I forgot to mention that I already have an OSGeo ID (manuelep),
> which I created for this purpose.
> Regards
>      M.
> Il 2025-08-25 07:29 manuele at inventati.org ha scritto:
> > Hello all,
> > my name is Manuele Pesenti, I work at Gter srl, the company that
> > develops and maintains the QGIS plugin CDU Creator.
> > Until now, the technical maintenance of the plugin was carried out by a
> > colleague who is no longer working at Gter.
> > For this reason, I have been asked to take over the role of maintainer
> > on behalf of the company.
> > I would like to kindly ask if this message is sufficient for the Plugin
> > Committee to update the maintainer information, or if you expect me to
> > provide additional details/documentation for the process.
> > Thank you for your support,
> > Best regards
> > Manuele Pesenti
> > Gter srl
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250825/def148ae/attachment-0001.htm>
More information about the QGIS-Developer mailing list
