[QGIS-Developer] Latest version of the QWC plugin is online but not proposed by extensions manager
Régis Haubourg regis.haubourg at gmail.com
Tue Dec 2 23:18:27 PST 2025
Hi all,
If the issue is only consistency between website and plugin manager , you can open an issue in the website. lova can change the website's behavior more easily than changing qgis core.
Hope this helps.
Régis
Le 2 décembre 2025 13:31:11 GMT+01:00, "Julien Moura (Oslandia) via QGIS-Developer" <qgis-developer at lists.osgeo.org> a écrit :
>Hi Laurențiu,
>Thanks for answering and for your hint. Indeed sorting on the version column shows up versions prefixed with 'v'... but it's really hard to understand:
>- on the website: v1.4.1 (also marked as "The latest stable version"), v1.4.0, v1.2.0, v1.0.1, 1.4.3... and the
>- on QGIS, the plugins manager features the version 1.4.2...
>I guess there is a consistency issue here...
>How can I move on since it's impossible to rename an approved version? Thanks for your help!
>Le 02/12/2025 à 11:23, Laurențiu Nicola via QGIS-Developer a écrit :
>> Hi Julien,
>> I've seen this in the past with other plugins. I think you're correct and this is caused by the lexicographic sort of versions, which you can double-check by sorting on that column.
>> Laurentiu
>> On Mon, Dec 1, 2025, at 17:51, Julien Moura (Oslandia) via QGIS-Developer wrote:
>>> Hello,
>>> Last Wednesday, we published version 1.4.3 of the QWC Tools plugin (formerly known as QWC2_Tools). It’s online and listed on https://plugins.qgis.org/plugins/qwc2_tools/#plugin-versions<https://plugins.qgis.org/plugins/qwc2_tools/#plugin-versions>, but the QGIS (tested on 3.40.13 and 3.44.5 on Ubuntu, using apt with official PPA) plugin manager still doesn’t show it (I only see the 1.4.2 version).
>>> Am I missing something? Is it because some versions are prefixed with a “v” and others are not?
>>> Thanks for your help,
>>> Julien
>>> Oslandia <https://oslandia.com/?utm_source=email&utm_campaign=signature_oslandia&utm_medium=email> - Livre blanc pour migrer/hybrider son SIG <https://oslandia.com/livre-blanc-migration-sig-opensource/?utm_source=email&utm_campaign=signature_oslandia&utm_medium=email>
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> *Attachments:*
>>>   * OpenPGP_signature.asc
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20251203/2ddc01c3/attachment.htm>
More information about the QGIS-Developer mailing list
