[QGIS-Developer] Experimental plugin flag, yes/no or True/False?
Lova Andriarimalala lova at kartoza.com
Thu Feb 13 01:05:42 PST 2025
Hi Raymond,
After uploading I did not check the experimental checkbox, as my
> metadata should override this anyway. (Why do both exist anyway??)
In my understanding, this has been implemented for the possibility of
checking the experimental when uploading, as this is not required in the
metadata.
However, my plugin was not published as experimental, but as a normal
> plugin discoverable for everyone.
> Now I remember that we used to have experimental=yes in the metadata, so
> the documentation might be wrong? Can anyone explain or check?
> Same counts for other boolean fields: deprecated, server and
> hasProcessingProvider.
> By the way, the new plugin website looks wonderful!! 🤩
Let me check this and get back to you. Thanks for reporting this, and thank
you also for the feedback.
Best regards.
Lova Andriarimalala
*QGIS Full Stack Developer   *
*T *: +27(0) 87 809 2702          *E *: lova at kartoza.com          *W* :
kartoza.com
*This email and any attachments are confidential and intended solely for
the use of the individual or entity to whom they are addressed. If you *
*have received this email in error, please notify the sender immediately
and delete it from your system. Unauthorised use, disclosure, or copying*
*of the contents is prohibited.*
On Thu, 13 Feb 2025 at 10:41, Raymond Nijssen via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Yesterday I uploaded a new plugin and I set the experimental flag in the
> metadata.txt to True, as it should be according to the documentation here:
> https://docs.qgis.org/testing/en/docs/pyqgis_developer_cookbook/plugins/plugins.html#id4
> (I mean the paragraph "16.1.2.1. metadata.txt" but the link doesn't
> exactly bring me there in my Browser.)
> Raymond
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250213/40c7664b/attachment.htm>
More information about the QGIS-Developer mailing list
