[QGIS-Developer] Tests failing since 2 days ago using docker qgis/qgis:stable
    Paolo Tormene
    paolo.tormene at globalquakemodel.org
    Wed Feb 26 02:36:16 PST 2025
Thank you very much, Nyall!
Following your hint, we managed to fix our tests also using the
qgis/qgis:stable docker.
Cheers,
Paolo
On Wed, Feb 26, 2025 at 3:13 AM Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On Tue, 25 Feb 2025 at 20:13, Paolo Tormene via QGIS-Developer
> <qgis-developer at lists.osgeo.org> wrote:
> > Dear QGIS developers,
> > we have some tests that ceased to work two days ago, running on docker
> qgis/qgis:stable, giving the following traceback:
> > Traceback (most recent call last):
> >   File "/usr/lib/python3/dist-packages/qgis/testing/__init__.py", line
> 1103, in start_app
> >     QGISAPP
> > NameError: name 'QGISAPP' is not defined
> Looks like you're running tests from WITHIN the QGIS application. In
> this case you should not be calling start_app(), as there is
> **already** a QGIS application running.
> QGIS 3.42 introduced new checks to explicitly prevent this, as it
> causes instability.
> Nyall
> > During handling of the above exception, another exception occurred:
> >   File "<string>", line 175, in __run_test
> >   File "<string>", line 70, in __get_test_function
> >   File "/usr/lib/python3.12/importlib/__init__.py", line 90, in
> import_module
> >     return _bootstrap._gcd_import(name[level:], package, level)
> >   File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
> >   File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
> >   File "<frozen importlib._bootstrap>", line 1331, in
> _find_and_load_unlocked
> >   File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
> >   File "<frozen importlib._bootstrap_external>", line 995, in exec_module
> >   File "<frozen importlib._bootstrap>", line 488, in
> _call_with_frames_removed
> >   File
> "/root/.local/share/QGIS/QGIS3/profiles/default/python/plugins/svir/test/integration/test_drive_oq_engine.py",
> line 58, in <module>
> >     QGIS_APP = start_app()
> 1130, in start_app
> >     QGISAPP.initQgis()
> > TypeError: _qgis_app_init_qgis() takes 0 positional arguments but 1 was
> given
> > The same tests run without issues using docker qgis/qgis:ltr.
> > Do you have any suggestions about this? Do you have any documentation
> about what changed in the stable docker two days ago, so we can have some
> hints on what we could further investigate?
> > Paolo
> > PAOLO TORMENE senior software developer +39 0382 5169882
> > GLOBAL EARTHQUAKE MODEL working together to assess risk
> > GEM - globalquakemodel.org T - @GEMwrld F - GEMwrld
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
*PAOLO TORMENE* senior software developer +39 0382 5169882
*GLOBAL EARTHQUAKE MODEL * working together to assess risk
*GEM -* globalquakemodel.org <http://www.globalquakemodel.org> *T -*
@GEMwrld <http://twitter.com/GEMwrld> *F -* GEMwrld
<http://www.facebook.com/GEMwrld>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250226/4e857141/attachment-0001.htm>
