[QGIS-Developer] Building QGIS with QT6 on Ubuntu: Python error at start
Alessandro Pasotti apasotti at gmail.com
Mon Jul 21 08:52:58 PDT 2025
Thanks, I'm using Python 3.13 (that comes with that Ubuntu version).
Now I'm trying with vcpkg ...
On Mon, Jul 21, 2025 at 5:35 PM pathmapper <pathmapper at posteo.de> wrote:
> Hi,
> I don't know what's wrong, but when I had similar problems, switching to
> Python 3.12 solved them for me.
> Cheers,
> Björn
> On 21.07.2025 16:58, Alessandro Pasotti via QGIS-Developer wrote:
> > Hi,
> > I am trying to build QGIS with QT6 on Ubuntu (tried 24.10 and 25.04),
> > it builds without errors but when I run it, the following error
> > appears:
> > Couldn't load PyQGIS.
> > Python support will be disabled.
> > Traceback (most recent call last):
> >   File "", line 1, in
> >   File
> "/home/ale/dev/QGIS/build/Desktop_QT6-Debug/output/python/qgis/gui/__init__.py",
> > line 25, in
> >     from qgis._gui import *
> > RuntimeError: qgis._gui cannot import type '���A� ' from
> > PyQt6.QtCore
> > Python version:
> > 3.13.3 (main, Jun 16 2025, 18:15:32) [GCC 14.2.0]
> > QGIS version:
> > 3.99.0-Master 'Master', e717e3cd2b9
> > Python path:
> > ['/home/ale/dev/QGIS/build/Desktop_QT6-Debug/output/python',
> > '/home/ale/.local/share/QGIS/QGIS3/profiles/default/python',
> > '/home/ale/.local/share/QGIS/QGIS3/profiles/default/python/plugins',
> > '/home/ale/dev/QGIS/build/Desktop_QT6-Debug/output/python/plugins',
> > '/home/ale/dev/gdal/desktop-install/local/lib/python3.13/dist-packages',
> > '/home/ale/dev/gdal/autotest/pymod', '/usr/lib/python313.zip',
> > '/usr/lib/python3.13', '/usr/lib/python3.13/lib-dynload',
> > '/usr/local/lib/python3.13/dist-packages',
> > '/usr/lib/python3/dist-packages']
> > I checked the QGIS/build/Desktop_QT6-Debug/output/python/qgis content
> > and it looks legit.
> > PyQt6 installation also looks ok, importing core works ok, only gui
> > does not work.
> > Any idea about what's going wrong?
> > Alessandro Pasotti
> > QCooperative:  www.qcooperative.net [1]
> > ItOpen:   www.itopen.it [2]
> > Links:
> > [1] https://www.qcooperative.net
> > [2] http://www.itopen.it
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alessandro Pasotti
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250721/dc36a542/attachment.htm>
More information about the QGIS-Developer mailing list
