[QGIS-Developer] Broken code test infrastructure in documentation repository
DelazJ delazj at gmail.com
Mon Jul 28 09:07:27 PDT 2025
Hi devs,
Starting at least from this monday morning (Paris time), doctest, the
infrastructure for testing code samples in docs is failing. This time, for
a good reason, should I add. It complains at the start of the global setup
with a *ModuleNotFoundError: No module named 'qgis'* error.
Considering that we did no changes related to this area in the last weeks
(tests passed two days ago), I suspect there is a change in QGIS code repo
that generates this situation. Maybe an underlying bug in QGIS itself?
Could be nice if someone can give it a look. Thanks a lot.
Example of action failing:
https://github.com/qgis/QGIS-Documentation/actions/runs/16571687193/job/46865383445#step:8:682
Executed configuration command:
https://github.com/qgis/QGIS-Documentation/blob/ab9f5f1d64e2e10a31af1f84294605aa69b24b3c/conf.py#L391
Kind regards,
Harrissou
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250728/9ce6a89c/attachment.htm>
More information about the QGIS-Developer mailing list
