[QGIS-Developer] Copy layer vs Duplicate layer ???
Richard Duivenvoorde rdmailings at duif.net
Wed Jun 4 08:00:40 PDT 2025
Hi People,
A user had an issue in which she 'copied' a layer, edited it and then found out she edited the original data...
My response was: yes (join the club ;-)) it is called 'duplicate', but it only duplicates the layer, NOT the data.
Then she responded: but I did not use 'duplicate', I used 'copy layer' ...
Then I found out they indeed both exist in the context menu, and actually do the same thing... ???
(tested with a gpkg and a shapefile)
So my questions:
- should there be 2 context menu items for the same thing (the always tricky 'duplicate' which (in my view) counter-intuitive does not duplicate data)
- should these 2 functions not behave different?
Regards,
More information about the QGIS-Developer mailing list
