[QGIS-Developer] Copy layer vs Duplicate layer ???
Andrea Giudiceandrea
andreaerdna at libero.it
Wed Jun 4 18:27:04 PDT 2025
Hi Richard and list,
the QGIS Desktop User Guide / Manual explains such functionalities,
clearly stating that "The copy uses the same data source as the
original." / "As for Duplicate, the layers are still based on the same
data source."
"Duplicate" a layer to generate a copy where you can modify the name,
style (symbology, labels, …), joins, … The copy uses the same data
source as the original.
"Copy" and "Paste" layers or groups from one project to another as a new
instance whose properties can be modified independently. As for
Duplicate, the layers are still based on the same data source.
See
https://docs.qgis.org/3.40/en/docs/user_manual/introduction/qgis_gui.html#layer
Regards.
Andrea
Il 04/06/2025 17:00, Richard Duivenvoorde via QGIS-Developer ha scritto:
> Hi People,
> A user had an issue in which she 'copied' a layer, edited it and then
> found out she edited the original data...
