[QGIS-Developer] two packaging questions
Greg Troxel gdt at lexort.com
Mon Jun 9 05:02:47 PDT 2025
Richard Duivenvoorde via QGIS-Developer <qgis-developer at lists.osgeo.org>
writes:
> My personal(!) view for Linux packaging (as Linux user, not packager).
> Stick to 3.40/LTR/Qt5 for QGIS3.
> (Well, that is what our Debian packager does, not sure what your users expect)
> One reason to have a Qt6 package available is that you give Plugin devs the ability to have Qt6 based QGIS so they have update/test their plugins.
> Because I foresee dependency issues (Debian), I'm testing the flatpak route, so Linux users can install a Qt6 build flatpak next to their Qt5 build for experiments.
> I'd say: QGIS4 is Qt6-only, but we need to have a Qt6 option (be it 3.40 or higher) available for (Linux) python devs.
Thanks.  I have been LTR only, but thinking about moving to following
all releases once they hit .1.  I do not perceive them as at all
unstable.
Sounds like I should add a qt5/qt6 option group, mostly the test that
the qt6 things are packaged and that it works, and then be prepared to
flip it for 4, and later remove it.
More information about the QGIS-Developer mailing list
