[QGIS-Developer] QGIS 3.44 projects compatibility with previous versions
Jorge Gustavo Rocha
jgr at di.uminho.pt
Thu Jun 12 05:47:31 PDT 2025
+1 to delay this breaking change or to follow a Denis' approach :-)
Jorge
Às 13:28 de 12/06/25, Denis Rouzaud via QGIS-Developer escreveu:
> Hi,
> I did something similar in the symbology area and I went for saving
> twice the data.
> We could probably leave the two at the same time in the same tag:
> <properties>
> <foo>
> <bar type="QString">baz</bar>
> </foo>
> <properties name="foo">
> <properties name="bar" type="QString">baz</properties>
> </properties>
> </properties>
> Old QGIS would only save the old, new QGIS would save both and use the
> new if it exists.
> Best of the 2 worlds?
> Cheers,
> Denis
> Le jeu. 12 juin 2025 à 13:55, Stefanos Natsis via QGIS-Developer
> <qgis-developer at lists.osgeo.org> a écrit :
> Hi list
> During the last dev cycle, a change was introduced in the way that
> properties are stored in the .qgs xml file
> https://github.com/qgis/QGIS/pull/60855
> While this solved a real issue (data-driven properties could
> result in an invalid property name with a leading digit) in an
> elegant way and is technically backwards compatible (projects
> generated with older versions can be opened without issues), it
> has the side effect that projects stored with 3.44 will not
> properly load in older QGIS versions (stored properties are
> ignored and also project CRS is undefined). Plugins could also
> malfunction as they often use project properties for storing their
> project-related configurations.
> One potential solution would be to backport this to LTR, however
> from my experience a good percentage of the users use older QGIS
> versions and even those on LTR do not always upgrade as soon as a
> new release is out, so backporting could eventually make things worse!
> With QGIS 4.0 around the corner, imho, it would be better to defer
> this change for a couple more months and only include this
> kind-of-breaking change in QGIS 4.0
> I briefly chatted with Jurgen at the hackfest about this and while
> acknowledging the issue, was not super happy to revert, so I'm
> interested in gathering more opinions here.
> Best
> Stefanos
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250612/f2f6c271/attachment-0001.htm>
