[QGIS-Developer] Experimental Qt6 Flatpak build available for Linux/Python devs (for updating plugins)
Johannes Kröger (WhereGroup)
johannes.kroeger at wheregroup.com
Mon Jun 16 07:16:46 PDT 2025
Oh, I meant not another Flatpak QGIS but really the system-wide QGIS
(/usr/bin/qgis). The system QGIS is still available via a terminal but
the Flatpak one has taken over "QGIS" in the GUI (in the "start" menus,
launchers, whatever those are called).
Maybe that is just on my system(s) though?
Cheers, Hannes
On 6/16/25 15:57, Richard Duivenvoorde wrote:
> I think this has to do with the fact that I did not change the id/name
> of the application.
> It's still called "org.qgis.qgis"...
> Maybe I should call it something like "org.qgis.qgis.next" or so?
> "org.qgis.qgis.qt6'?
> Then I think it will not conflict with the normal flatpak qgis...
> Regards,
> On 16-06-2025 15:08, Johannes Kröger (WhereGroup) wrote:
>> Thank you, this is super useful!
>> Is there a way to make it not mask my system QGIS? After I installed
>> this on Manjaro or Ubuntu, it took over "QGIS" in the launcher menu.
>> The only way I could still run my normal QGIS was via "qgis" in the
>> terminal.
>> I expect this to be some configuration setting of flatpak itself, but
>> found literally nothing via Google. So maybe it is something flatpak
>> build specific or my Google fu has broken.
>> Cheers, Hannes
>> On 6/11/25 16:48, Richard Duivenvoorde via QGIS-Developer wrote:
>>> Hi,
>>> Based on the excellent Flatpak work of Aleix Pol
>>> (https://github.com/flathub/org.qgis.qgis), I managed to create a
>>> runnable Qt6 build of QGIS for Linux's (with flatpak available)
>>> My idea is that Linux users of distro's without the needed
>>> dependencies can run QGIS and test/update their Python plugins with
>>> this build.
>>> This flatpak build (master) is (thanks to Aleix!) having 3D and
>>> PDAL/cloudpoint available too.
>>> Note that this is my first flatpak build, probably things go/are
>>> wrong, and I'm not sure how to do further/future distribution...
>>> But for now: to run/try it:
>>> Download the single-bundle file from
>>> http://duif.net/qgis-qt6.flatpak
>>> If you do not have flatpak/flathub available, make sure you do by
>>> doing the steps at
>>> https://flatpak.org/setup/ for your distro, to
>>> 1) install flatpak and
>>> 2) make the flathub repo available for needed runtimes and sdk's.
>>> Now go to the qgis-qt6.flatpak file and INSTALL it:
>>> flatpak install --runtime --include-sdk qgis-qt6.flatpak
>>> (this will install the KDE runtime and sdk and then finally the
>>> qgis-qt6 system wide)
>>> Then to run it:
>>> flatpak run org.qgis.qgis
>>> I hope this is useful for anybody.
>>> Have to talk to Aleix for more finesses to maybe share this on
>>> flathub or with his Qt5 build.
>>> If you want to build it yourself there is some info in:
>>> https://github.com/flathub/org.qgis.qgis/issues/428
>>> Regards,
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Johannes Kröger / GIS-Entwickler/-Berater
Schon gewusst?
In unserem Blog geben wir Tipps & Tricks zu Open-Source-GIS-Software
und berichten aus unserem Experten-Alltag:
https://wheregroup.com/blog/
WhereGroup GmbH
c/o KK03 GmbH
Lange Reihe 29
20099 Hamburg
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
