[QGIS-Developer] Experimental Qt6 Flatpak build available for Linux/Python devs (for updating plugins)
Johannes Kröger (WhereGroup) johannes.kroeger at wheregroup.com
Tue Jun 17 00:13:49 PDT 2025
Hi Ulisse,
yes, that was it, thank you!
For my case the solution is simply removing the desktop file of the
Flatpak QGIS:
/sudo rm /var/lib/flatpak/exports/share/applications/org.qgis.qgis.desktop
sudo update-desktop-database/
Now my system QGIS is working as intended and I can use the Flatpak QGIS
for testing via
/flatpak run org.qgis.qgis/
Cheers, Hannes
On 6/16/25 16:39, Ulisse Cavallini via QGIS-Developer wrote:
> Hi Hannes,
> this could be due to the fact that the flatpak .desktop file has the
> same "Name". You could solve this by copying both the .desktop files
> (flatpak and system-wide) in your user application directory, for
> example (local paths may vary):
> /cp /usr/share/applications/org.qgis.qgis.desktop
> ~/.local/share/applications//
> /cp /var/lib/flatpak/exports/share/applications/org.qgis.qgis.desktop
> and change the name of one of the two (Name attribute), for example
> setting "QGIS Desktop Flatpak Qt6"
> Should be automatically picked up, otherwise you can run
> /update-desktop-database ~/.local/share/applications/
> See also
> https://wiki.archlinux.org/title/Desktop_entries#Modify_desktop_files
> I hope this helps!
> Cheers,
> Ulisse
> On 6/16/25 4:16 PM, Johannes Kröger (WhereGroup) via QGIS-Developer wrote:
>> Oh, I meant not another Flatpak QGIS but really the system-wide QGIS
>> (/usr/bin/qgis). The system QGIS is still available via a terminal
>> but the Flatpak one has taken over "QGIS" in the GUI (in the "start"
>> menus, launchers, whatever those are called).
>> Maybe that is just on my system(s) though?
>> Cheers, Hannes
>> On 6/16/25 15:57, Richard Duivenvoorde wrote:
>>> I think this has to do with the fact that I did not change the
>>> id/name of the application.
>>> It's still called "org.qgis.qgis"...
>>> Maybe I should call it something like "org.qgis.qgis.next" or so?
>>> "org.qgis.qgis.qt6'?
>>> Then I think it will not conflict with the normal flatpak qgis...
>>> Regards,
>>> On 16-06-2025 15:08, Johannes Kröger (WhereGroup) wrote:
>>>> Thank you, this is super useful!
>>>> Is there a way to make it not mask my system QGIS? After I
>>>> installed this on Manjaro or Ubuntu, it took over "QGIS" in the
>>>> launcher menu. The only way I could still run my normal QGIS was
>>>> via "qgis" in the terminal.
>>>> I expect this to be some configuration setting of flatpak itself,
>>>> but found literally nothing via Google. So maybe it is something
>>>> flatpak build specific or my Google fu has broken.
>>>> Cheers, Hannes
>>>> On 6/11/25 16:48, Richard Duivenvoorde via QGIS-Developer wrote:
>>>>> Hi,
>>>>> Based on the excellent Flatpak work of Aleix Pol
>>>>> (https://github.com/flathub/org.qgis.qgis), I managed to create a
>>>>> runnable Qt6 build of QGIS for Linux's (with flatpak available)
>>>>> My idea is that Linux users of distro's without the needed
>>>>> dependencies can run QGIS and test/update their Python plugins
>>>>> with this build.
>>>>> This flatpak build (master) is (thanks to Aleix!) having 3D and
>>>>> PDAL/cloudpoint available too.
>>>>> Note that this is my first flatpak build, probably things go/are
>>>>> wrong, and I'm not sure how to do further/future distribution...
>>>>> But for now: to run/try it:
>>>>> Download the single-bundle file from
>>>>> http://duif.net/qgis-qt6.flatpak
>>>>> If you do not have flatpak/flathub available, make sure you do by
>>>>> doing the steps at
>>>>> https://flatpak.org/setup/ for your distro, to
>>>>> 1) install flatpak and
>>>>> 2) make the flathub repo available for needed runtimes and sdk's.
>>>>> Now go to the qgis-qt6.flatpak file and INSTALL it:
>>>>> flatpak install --runtime --include-sdk qgis-qt6.flatpak
>>>>> (this will install the KDE runtime and sdk and then finally the
>>>>> qgis-qt6 system wide)
>>>>> Then to run it:
>>>>> I hope this is useful for anybody.
>>>>> Have to talk to Aleix for more finesses to maybe share this on
>>>>> flathub or with his Qt5 build.
>>>>> If you want to build it yourself there is some info in:
>>>>> https://github.com/flathub/org.qgis.qgis/issues/428
>>>>> Regards,
>>>>> _______________________________________________
>>>>> QGIS-Developer mailing list
>>>>> QGIS-Developer at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Ulisse Cavallini
> www.faunalia.eu
> Training, support, development on QGIS, PostGIS and more
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
Johannes Kröger / GIS-Entwickler/-Berater
Schon gewusst?
In unserem Blog geben wir Tipps & Tricks zu Open-Source-GIS-Software
und berichten aus unserem Experten-Alltag:
https://wheregroup.com/blog/
WhereGroup GmbH
c/o KK03 GmbH
Lange Reihe 29
20099 Hamburg
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250617/bc0efebb/attachment.htm>
More information about the QGIS-Developer mailing list
