[QGIS-Developer] Calculate area/perimtere/length of polygon/line while editing
    Sylvain Théry
    sylvain.thery at cnrs.fr
    Tue Mar 11 09:05:15 PDT 2025
Hello,
It seems there is a fix here :
https://github.com/agiudiceandrea/calcarea2/blob/a6a3d7c5a98e64573731cd6a005da4e2d9836fdd/calcareaevent.py
All the best,
S.
Le 11/03/2025 à 16:14, Catania, Luke A ERDC-RDE-GRL-VA CIV via
QGIS-Developer a écrit :
> Thanks. Plugin installed but will not run.  I get the error below. I
> have QGIS 3.34.4.
> *TypeError: QgisInterface missing 'mActionDigitizeWithCurve' action *
> Traceback (most recent call last):
>   File "C:\PROGRA~1/QGIS33~1.4/apps/qgis-ltr/./python\qgis\utils.py",
> line 423, in _startPlugin
>     plugins[packageName] = package.classFactory(iface)
>   File
> "C:\Users/RDTECLAC/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\calcarea2\__init__.py",
> line 29, in classFactory
>     return CalcAreaPlugin( iface )
>   File
> "C:\Users/RDTECLAC/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\calcarea2\plugin.py",
> line 66, in __init__
>     self.toolEvent = CalcAreaEvent( self.iface )
>   File
> "C:\Users/RDTECLAC/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\calcarea2\calcareaevent.py",
> line 478, in __init__
>     self.addFeatureEvent = AddFeatureEvent( iface )
>   File
> line 213, in __init__
>     self.geomPolygon = self.GeomPolygon( iface )
>   File
> line 316, in __init__
>     self.actionDigitizeWithCurve = getActionDigitizeWithCurve( iface )
>   File
> line 308, in getActionDigitizeWithCurve
>     raise TypeError(f"QgisInterface missing '{name}' action")
> *From:*DelazJ <delazj at gmail.com>
> *Sent:* Tuesday, March 11, 2025 11:08 AM
> *To:* Catania, Luke A ERDC-RDE-GRL-VA CIV <Luke.A.Catania at erdc.dren.mil>
> *Cc:* qgis-developer at lists.osgeo.org
> *Subject:* Re: [QGIS-Developer] Calculate area/perimtere/length of
> Hi,
> There is a CalcArea2 plugin whose description mentions it should be
> doing that for polygons. You might want to take ispiration from their
> code.
> Regards,
> Harrissou
> Le mar. 11 mars 2025 à 15:55, Catania, Luke A ERDC-RDE-GRL-VA CIV via
> QGIS-Developer <qgis-developer at lists.osgeo.org> a écrit :
>     I need to calculate these values on the fly while I am in an edit
>     session resizing a polygon or a line.  I need the user to see this
>     calculation while they are editing not after the edits are
>     committed. I already have the UI set up to capture after commit,
>     but I need to capture while they are moving vertices and update
>     the values in the UI, so they don’t keep editing and then
>     committing just to see if they are close.  I want them to know
>     before they commit.
>     Any idea how to achieve this?
>     Luke Catania
>     US Army ERDC-GRL
>     JCMS Site Planning Developer
>     _______________________________________________
>     QGIS-Developer mailing list
>     QGIS-Developer at lists.osgeo.org
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     <Blockedhttps://lists.osgeo.org/mailman/listinfo/qgis-developerBlocked>
>     Unsubscribe:
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
Sylvain THÉRY - Ingénieur d'études CNRS en géomatique
UMR 5281 ART-Dev - Acteurs, Ressources et Territoires dans le Développementhttps://art-dev.cnrs.fr/
sylvain.thery at cnrs.fr  - +33.4.11.75.70.98
Université Paul-Valéry Montpellier 3 - Site St Charles - Bureau 239
@ postale : ART-Dev - St Charles - Route de Mende - 34 199 Montpellier Cedex 5
https://www.researchgate.net/profile/Sylvain-Thery
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250311/5ac92921/attachment.htm>
Type: application/pkcs7-signature
Desc: Signature cryptographique S/MIME
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250311/5ac92921/attachment.bin>
