[QGIS-Developer] SharePoint_QGIS issue
ENNAFTI Tayssir tayssir.ennafti at arkema.com
Wed May 21 02:45:24 PDT 2025
Hello,
We are using QGIS to regularly edit shapefiles and raster data stored on SharePoint. However, we've run into an issue: SharePoint paths are user-specific (e.g., C:\Users\[username]...), which breaks shared access across multiple users in QGIS.
We are specifically looking for a way to save files directly on SharePoint, rather than on the local synced copy, which remains tied to a specific user profile.
For info , we are using  3.34.0 version.
Any guidance or suggestions would be greatly appreciated.
Best regards,
Tayssir ENNAFTI
Stagiaire Géotechnicienne et Data Scientist
Technical Division
P +33472396872
[cid:image001.png at 01DBCA44.C0721350]<http://www.arkema.com/>   [cid:image002.jpg at 01DBCA44.C0721350] <http://www.twitter.com/Arkema_group>         [cid:image003.jpg at 01DBCA44.C0721350] <https://linkedin.com/company/arkema>         [cid:image004.jpg at 01DBCA44.C0721350] <https://www.youtube.com/c/ArkemaGroup>         [cid:image005.jpg at 01DBCA44.C0721350] <http://www.instagram.com/Arkemagroup>         [cid:image006.jpg at 01DBCA44.C0721350] <http://www.facebook.com/ArkemaGroup>
Centre Technique, Informatique et Administratif
11, Chemin de la Lône, BP 32
69492 Pierre-Bénite FRANCE
Ce courriel, pièces jointes incluses, peut contenir des informations confidentielles et/ou couvertes par le secret professionnel et/ou propriété du Groupe Arkema ou de tiers. Il ne peut être utilisé que dans le cadre de son objet. Si vous n'en êtes pas le destinataire, merci d'en informer l'expéditeur par retour et de supprimer ce courriel sans le lire, le copier ni le distribuer. Merci.
This e-mail, attachments included, may contain information that is confidential and/or privileged and/or proprietary to the Arkema Group or third party. It may only be used for its intended purpose. If you are not the intended recipient, please advise the sender by return and delete this e-mail without reading, copying nor distributing it. Thank you.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250521/37b6f69d/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250521/37b6f69d/attachment-0001.png>
Type: image/jpeg
Desc: image002.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250521/37b6f69d/attachment-0005.jpg>
Type: image/jpeg
Desc: image003.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250521/37b6f69d/attachment-0006.jpg>
Type: image/jpeg
Desc: image004.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250521/37b6f69d/attachment-0007.jpg>
Type: image/jpeg
Desc: image005.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250521/37b6f69d/attachment-0008.jpg>
Type: image/jpeg
Desc: image006.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250521/37b6f69d/attachment-0009.jpg>
More information about the QGIS-Developer mailing list
