[QGIS-Developer] SharePoint_QGIS issue
Denis Rouzaud
denis.rouzaud at gmail.com
Wed May 21 21:53:50 PDT 2025
Hi
I think that localized data path would solve the problem
https://docs.qgis.org/latest/en/docs/user_manual/introduction/qgis_configuration.html
It would required to be configured on each station but there are tools to
help this such as
https://qgis-deployment.github.io/qgis-deployment-toolbelt-cli/index.html
Best regards
Denis
Le mer. 21 mai 2025, 11:45, ENNAFTI Tayssir via QGIS-Developer <
qgis-developer at lists.osgeo.org> a écrit :
> Hello,
> We are using QGIS to regularly edit shapefiles and raster data stored on
> SharePoint. However, we've run into an issue: SharePoint paths are
> user-specific (e.g., C:\Users\[username]...), which breaks shared access
> across multiple users in QGIS.
> We are specifically looking for a way to save files directly on
> SharePoint, rather than on the local synced copy, which remains tied to a
> specific user profile.
> For info , we are using 3.34.0 version.
> Any guidance or suggestions would be greatly appreciated.
> Best regards,
> *Tayssir ENNAFTI*
> Stagiaire Géotechnicienne et Data Scientist
> Technical Division
> P +33472396872
> <http://www.arkema.com/> <http://www.twitter.com/Arkema_group>
> <https://linkedin.com/company/arkema>
> <https://www.youtube.com/c/ArkemaGroup>
> <http://www.instagram.com/Arkemagroup>
> <http://www.facebook.com/ArkemaGroup>
> Centre Technique, Informatique et Administratif
> 11, Chemin de la Lône
> <https://www.google.com/maps/search/11,+Chemin+de+la+L%C3%B4ne?entry=gmail&source=g>,
> BP 32
> 69492 Pierre-Bénite FRANCE
> Ce courriel, pièces jointes incluses, peut contenir des informations
> confidentielles et/ou couvertes par le secret professionnel et/ou propriété
> du Groupe Arkema ou de tiers. Il ne peut être utilisé que dans le cadre de
> son objet. Si vous n'en êtes pas le destinataire, merci d’en informer
> l’expéditeur par retour et de supprimer ce courriel sans le lire, le copier
> ni le distribuer. Merci.
> This e-mail, attachments included, may contain information that is
> confidential and/or privileged and/or proprietary to the Arkema Group or
> third party. It may only be used for its intended purpose. If you are not
> the intended recipient, please advise the sender by return and delete this
> e-mail without reading, copying nor distributing it. Thank you.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250522/e4cce175/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250522/e4cce175/attachment-0002.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250522/e4cce175/attachment-0010.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250522/e4cce175/attachment-0011.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250522/e4cce175/attachment-0012.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250522/e4cce175/attachment-0013.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250522/e4cce175/attachment-0014.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250522/e4cce175/attachment-0015.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250522/e4cce175/attachment-0016.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250522/e4cce175/attachment-0017.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250522/e4cce175/attachment-0018.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250522/e4cce175/attachment-0003.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250522/e4cce175/attachment-0019.jpg>
