[QGIS-Developer] Development environment setup
Tom Christian tom at sparkgeo.com
Wed Nov 12 09:20:15 PST 2025
Hi Greg, thanks for your input. Regarding this:
> I find the choices that give rise to this approach to be problematic.
> Containers are a useful device for someone to choose, but if people feel
> they have to use a container, that's a clue that the situation is
> troubled.
> I suspect you are running into packages which require an exact
> dependency, rather than the proper approach of having a minimal version,
> trying hard to not to raise that without cause, and adapating to any
> released version >= the minimum.   Some upstreams, influenced by
> language-specific packaging tools, take the approach that their package
> is the most important thing in the world and therefore it's ok to insist
> on exact versions.
> So far, it seems that qgis does very well on not being unreasonable
> about dependencies (as long as gcc 12 turns out to be ok; see below).
If the QGIS repo is good at managing its dependencies in a way that limits its impact on the rest of my system - that's great. The problem is that any other repo could manage its dependencies differently. Over the past year I've probably worked across 50 different repos, many of which I do not maintain and cannot manage their dependencies. If I don't attempt to isolate each project within Conda, containers, or a VM then I am at risk of surprise breakages from what should be unrelated repos. In any repos that I do maintain I provide a containerised option whenever possible to ease the lives of other contributors.
> However, I think it's important for it to be reasonable to build without
> containers.
I agree - I'm not suggesting QGIS should _only_ build and run in a container, but I think the option of building and running in a container could be better supported and I'm happy to contribute to that effort if others also want it.
Tom
More information about the QGIS-Developer mailing list
