[QGIS-Developer] Execute SQL tool
Alessandro Pasotti
apasotti at gmail.com
Fri Oct 17 01:09:19 PDT 2025
Hi Raymond,
The long-term goal is still to replace the python implementation of DB
manager with a C++ core implementation accessible from the browser, we are
not there yet but significant steps in that direction have been made.
Regarding your issues, I think the first step is to add your
enhancement/bugfixing requests and specify when they are related to a
specific provider (GPKG -> OGR).
Please note that in the filtered list of existing issues there are a few
unrelated ones (there is a processing algorithm with a similar name).
Kind regards.
On Thu, Oct 16, 2025 at 1:22 PM Raymond Nijssen via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Dear devs,
> Lately I've been working with the Execute SQL tool on gpkg database
> files, cause I'm trying to switch from the DB Manager to the QGIS native
> tool. I was told the DB Manager is going to be deprecated in the near
> future. Is that the goal?
> I'm wondering if other people are using the 'Execute SQL' tool as well,
> as I'm not really satisfied with the current functionality and I cannot
> find any complains in the mailing list or github issues.
> Some problems I encounter:
> * The result table is (randomly?) not showing the FID or other PK
> columns, nor the geometry column. But those are often important while
> writing SQL queries.
> * Loading the QueryLayer always creates a multigeometry layer not
> showing anything on the map. (Btw I think QGIS should be able to render
> multigeometries, or at least to set a 'point', 'line' or 'polygon' style
> to the multigeometry layer to force it rendering that type.)
> * The cursor somehow jumps randomly to other lines when (re)focusing on
> the SQL S
> * The clear button works *very* well, when you accidentally press it you
> loose the entire query without warning and ctrl-Z won't bring it back.
> * The error widget is large and leaving only a few lines of the SQL
> editor to find an fix my error. The splitter between them does not show
> the handle for resizing the widgets.
> If developers are interested in fixing this, please let me know. I'm
> happy to help and test and I can also try finding some funding for this.
> For me, a more productive SQL tool in QGIS would be:
> * In a dockable panel
> * Connected to one or more layers that update every time I execute my
> SQL (like the map in DBeaver)
> QGIS could be the best geo SQL editor in the world!
> There are current issues:
> https://github.com/qgis/QGIS/issues?q=is%3Aissue%20state%3Aopen%20%27execute%20sql%27
> Should I add all mine?
> Kind regards,
> Raymond
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alessandro Pasotti
QCooperative: www.qcooperative.net
ItOpen: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20251017/7296cb56/attachment.htm>
