[QGIS-Developer] PSA: do NOT build QGIS with libspatialindex >= 2.0
Mathieu Pellerin nirvn.asia at gmail.com
Mon Sep 15 18:01:55 PDT 2025
The vcpkg port of the library was still at 2.0.0 until roughly a month ago.
That means our vcpkg-reliant CI builds shouldn't be impacted.
On Tue, Sep 16, 2025, 7:39 AM Nyall Dawson via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> On Tue, 16 Sept 2025 at 10:37, Nyall Dawson <nyall.dawson at gmail.com>
> wrote:
>> Hi list,
>> While tracking down the failures from
>> https://github.com/qgis/QGIS/pull/63180, it's revealed that using QGIS
>> with libspatialindex >= 2.0 gives completely misleading results for nearest
>> neighbour geometry searches.
>> The root cause is an optimisation from the upstream library (
>> https://github.com/libspatialindex/libspatialindex/commit/6fe9ff769243579ed74f7f27409dd1dda6591634)
>> that breaks how downstream clients could previously implement custom
>> nearest neighbour comparators. From my research I don't think this is
>> fixable in QGIS, and will need an upstream fix.
> Sorry -- to clarify, that should have been >= 2.1 . 2.0 did not include
> the offending commit.
> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250916/9c5c453d/attachment.htm>
More information about the QGIS-Developer mailing list
