[QGIS-Developer] Reduced compatibility with old PosgreSQL/PostGIS databases in v. 4.0.0
Carlo A. Bertelli (Charta s.r.l.)
carlo.bertelli at gmail.com
Wed Apr 1 08:54:46 PDT 2026
Thanks for the explanation. Maybe I could create a function on the database
just to send something sufficiently appeasing to QGIS.
Buona Pasqua!
c
On Wed, Apr 1, 2026 at 1:52 PM Régis Haubourg <regis.haubourg at gmail.com>
wrote:
> Hi,
> This is pretty simple,
> QGIS queries a bunch of things against the catalog system table to
> understand the capabilities of the server, tables, access privileges and so
> on. This query fails because pg_is_in_recovery() function does not exist in
> postgres 8.4. on QGIS side, it hasn't changed since 2 years:
> https://github.com/qgis/QGIS/commit/d3474e4e2f258676c75bba874485b816b262acc2
> This has nothing to do with the URI.
> GDAL does not need as many system queries because it is not a GUI tool, so
> there is less chances it breaks.
> This has changed between 3.34 and 3.40, to fix a crash
> https://github.com/qgis/QGIS/pull/57810
> So, it is probable we don't add a If statement to handle PG 8.4. This
> function landed in 9.0 in postgres.
> Cheers
> Régis Haubourg
> On 31/03/2026 22:00, Carlo A. Bertelli (Charta s.r.l.) wrote:
> Thanks to everyone for replying so quickly to this problem.
> I totally agree with you about the necessity to upgrade PostgreSQL and I
> think it's not a good idea to risk adding bugs to a foundation library as
> GDAL.
> Anyway, I tried version 3.12.3 and it supports reading from a table and
> writing to it without problems. But something changed at least on version
> 4.0.0 for MacOS.
> While the DBManager recognized the table structure, the datasource browser
> doesn't and complains:
>> Error retrieving fields information for uri: bname='mydb' host=d
>> b.myclientshost.com port=5432 user='mypooruser' sslmode=disable
>> checkPrimaryKeyUnicity='O' table="oneschema". "mypolytable"
> when browsing fields.
> Maybe it has something to do with *uri: *bname which obviously means *uri:
> dbname* but the typo would break something if it is used in the code.
> This is the PostGIS error I get when retrieving this layer:
> 2026-03-31T21:39:29 WARNING Erroneous query: SELECT
>> has_table_privilege('"oneschema".
>> "mypolytable"','SELECT'),pg_is_in_recovery(),current_schema()
>> ,has_any_column_privilege('"oneschema".
>> "mypolytable"','INSERT'),has_table_privilege('"oneschema".
>> "mypolytable"','DELETE'),has_any_column_privilege('"oneschema".
>> "mypolytable"','UPDATE'),'f' returned 7 [ERROR: function
>> pg_is_in_recovery() does not exist
>> LINE 1: ...vilege('"oneschema".
>> "mypolytable"','SELECT'),pg_is_in_r...
>> HINT: No function matches the given name and argument types.
>> You might need to add explicit type casts.
>> 2026-03-31T21:39:29 WARNING Unable to determine table access
>> privileges for the "oneschema". "mypolytable" relation.
>> The error message from the database was:
>> ERROR: function pg_is_in_recovery() does not exist
>> SQL: SELECT has_table_privilege('"oneschema".
>> 2026-03-31T21:46:13 WARNING Erroneous query: SELECT
>> "mypolytable"','UPDATE'),has_column_privilege('"oneschema".
>> "mypolytable"','GEOMETRY','UPDATE') returned 7 [ERROR: function
>> 2026-03-31T21:46:13 WARNING Unable to determine table access
> while getting the same data by gdalinfo does not need any special
> privilege. I should be able to understand what this repeated error means on
> the SQL side, but it seems a complete nonsense to me. I'm sure someone
> would detect the reason for it.
> Is there a way to mitigate it? I was trying to use a virtual ogr file to
> handle misbehaving columns; I could convert some specific table to
> Spatialite, but I think solving my problem could be useful to someone else.
> Thanks in advance for any hint provided.
> c
> On Tue, Mar 31, 2026 at 8:26 PM Régis Haubourg via QGIS-Developer <
> qgis-developer at lists.osgeo.org> wrote:
>> 9.1 has reached end of life 10 years ago!
>> I'm with Even here. A Postgres server out of maintenance period must be
>> considered insecure and outdated and must totally be upgraded anyway.
>> Cheer, Régis
>> On 31/03/2026 18:14, Stefanos Natsis via QGIS-Developer wrote:
>> > One breaking change I'm aware of in QGIS 4 is that we've used the
>> > `CREATE TABLE IF NOT EXISTS` idiom for the `qgis_projects` table (for
>> > storing projects in the database) which was introduced in PostgreSQL 9.1
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260401/c0704a8a/attachment-0001.htm>
