[QGIS-Developer] How do I change the email associated with a plugin?
Lova Andriarimalala
lova at kartoza.com
Tue Aug 4 06:04:34 PDT 2026
Hi Ian,
You can update the email address associated with your plugin directly in
the plugin's Edit form on the QGIS Plugins website (
https://plugins.qgis.org/plugins/osgb-plugin/update/). It's also advised to
update the email address in the metadata.txt if you ever upload a new
version in the future.
I hope this helps,
Best regards,
Lova Andriarimalala
*QGIS Full Stack Developer *
*T *: +27(0) 87 809 2702 *E *: lova at kartoza.com *W* :
kartoza.com
*This email and any attachments are confidential and intended solely for
the use of the individual or entity to whom they are addressed. If you *
*have received this email in error, please notify the sender immediately
and delete it from your system. Unauthorised use, disclosure, or copying*
*of the contents is prohibited.*
On Mon, 3 Aug 2026 at 17:52, Ian Turton via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> I have discovered that one of my plugins is associated with an old work
> address that no longer exists, how do I go about changing it?
> It's https://plugins.qgis.org/plugins/osgb-plugin/#plugin-details if that
> helps
> Cheers
> Ian
> Ian Turton
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260804/ef2c2fbb/attachment.htm>
