[QGIS-Developer] Slow WCS processing and Clipping WCS by extent not working
Raymond Nijssen
r.nijssen at terglobo.nl
Wed Aug 19 05:18:47 PDT 2026
Just uploaded a processing script for downloading WCS, as a work around
for this problem:
https://hub.qgis.org/scripts/17/
But hopefully it can be fixed in QGIS somehow. Any ideas anyone?
Raymond
On 8/14/26 08:29, Raymond Nijssen via QGIS-Developer wrote:
> Created an issue too:
> https://github.com/qgis/QGIS/issues/67061
> On 8/14/26 07:02, Raymond Nijssen via QGIS-Developer wrote:
>> Dear developers,
>> Currently I'm working on a process that uses a WCS service containing
>> elevation data. I need 800x800m pieces from the elevation raster.
>> My graphical model uses a Raster Calculator algorithm, with one of the
>> (2) layers being the WCS layer from my project. This works but is very
>> slow. It takes about 1 minute to process the 800x800m calculation.
>> If I download the raster using gdal_translate, it only takes 2 seconds
>> or so. I cannot find out what the Raster Calculator is doing differently.
>> On top of that, I need to do calculations for the same area 3x, so
>> every location takes up over 3 minutes, and my entire process with
>> many locations over 6 hours.
>> So I had some ideas to speed this up, but so far they all have
>> downsides and I'm not sure what is the best way to proceed:
>> 1. Using the Raster Calculator with only one layer and storing the
>> output for the next 3 calculations. Will still take 1 minute extra,
>> but is more effective (and a bit lame).
>> 2. Using the Clip Raster by Extent algorithm, which seems perfect for
>> this. But it does not work for WCS, cause it parses the QGIS layer
>> source string directly into gdal_translate but GDAL needs another
>> string and throws an error. Looking at the Python source code, this
>> has probably never worked for WCS.
>> 2a. Fixing the Clip Raster by Extent algorithm. Cause it is in
>> Python, I can give it a try. But I already found out that the Clip
>> Raster by Mask algorithm has the same issue. And maybe more raster
>> algorithms do. So that should be solved in less redundant way, right?
>> 2b. Asking a core developer to rewrite this properly in c++. Maybe
>> in a way that uses the QGIS network manager so the http-calls get
>> shown in the debugging panel? No idea what this would cost but I think
>> I can get this funded somehow.
>> 3. Making my own Python WCS downloader algorithm in Python (I think I
>> will need to do this anyway to deliver my project on time, but I
>> prefer more long term solutions for all QGIS users.)
>> Any suggestions?
>> Kind regards,
>> Raymond
>> Some data
>> This is the GDAL command QGIS generates to clip the extent (2) and the
>> error:
>> GDAL command:
>> gdal_translate -projwin 148100.0 412300.0 148900.0 411500.0 -of GTiff
>> "cache=AlwaysNetwork&crs=EPSG:28992&format=GEOTIFF&identifier=dsm_05m&url=https://service.pdok.nl/rws/actueel-hoogtebestand-nederland/wcs/v1_0" /tmp/processing_NXPMbm/6597707893384cf9b74c2603ab45909d/OUTPUT.tif
>> GDAL command output:
>> ERROR 4:
>> cache=AlwaysNetwork&crs=EPSG:28992&format=GEOTIFF&identifier=dsm_05m&url=https://service.pdok.nl/rws/actueel-hoogtebestand-nederland/wcs/v1_0: No such file or directory
>> Process returned error code 1
>> This is the working WCS, url generated by QGIS and copied from the
>> debugging panel:
>> https://service.pdok.nl/rws/actueel-hoogtebestand-nederland/wcs/v1_0?
>> SERVICE=WCS&VERSION=1.0.0&REQUEST=GetCoverage&FORMAT=GEOTIFF&COVERAGE=dsm_05m&BBOX=142327.30414899752940983,408519.58202700602123514,156029.62145483330823481,415020.39733971789246425&CRS=EPSG:28992&RESPONSE_CRS=EPSG:28992&WIDTH=704&HEIGHT=334
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
