[QGIS-Developer] The squash, the merge, and the commit: What policy ?
David Signer david at opengis.ch
Fri Aug 28 00:04:59 PDT 2026
Thanks Valentin.
Sounds all good to me. As long as there is the exception you mentioned
where a contributor can organize multiple (few) atomic commits in the same
PR and merge them as they are.
Cheers
Dave
On Fri, Aug 28, 2026 at 2:02 AM Valentin Buira via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hi devs,
> As the subject of my email suggests, I would like to open up a
> discussion on our commit policy. And ultimately, how do we handle the
> end of life of a PR. I think there are instances in our workflow where
> there is a loss of history and information for git blame and other git
> tools, because the commits that matter are buried within less
> important commits.
> I think the biggest culprit of noisy history in the git tree is
> commits that should exist only in the span of a branch get merged into
> master.
> For example, imagine you are working on a feature with two commits
> initially, and during review you happen to completely change the
> implementation, then, after one final review you would have a local
> history that looks like this:
>   * Merge into master commit
>    |     * commit D fix typos, grammar, address final review
>    |     * commit C completely reworked the PR pls forget about A and B
>    |     * commit B
>    |     * commit A
> On merge, commits A, B, and D get into the tree history and in the
> inline git blame,  yet they don't matter for eyes outside of the local
> branch.
> Today, the PR description is the actual authoritative reference, and I
> believe this is what should get in the history tree instead of
> intermediate work commits.
> * Because of this configuration, two things happen at the same time.
> There is a loss of information for the git blame, overridden by the
> latest meaningless commit message e.g "apply suggestion from code
> review" "grammar". And at the same time, commits that are already
> outdated as soon as they leave their working branch get merged into
> the main branch anyway.
> * Related to my previous point, git bisect to find regressions is made
> more difficult because of noisy commits in-between the real changes.
> * Reverting and cherry-picking a single feature is harder. When
> reverting a PR, we have to revert as many commits as there were in the
> original PR. The same applies to cherry picking.
> * Vendor lock-in with Github. This one is adjacent to git but also
> blends with it.
> Currently, my workflow to understand a commit is the following : git
> blame > open commit on github > click on the PR associated with the
> commit to get the full picture of the changes.
> So to effectively understand the history of QGIS we are effectively
> dependent on github.
> And I think github is becoming a liability. The uptime of github is
> noticeably lower than it used to be. We are subject to any policies
> they want regardless of how we feel (e.g their pro AI stance). And
> more broadly github is based in the USA, which also means a lot of
> uncertainty on what the current US administration could do next.
> Unfortunately even switching to another git forge would make it
> difficult to retrieve the history we have today embedded in github.
> And now for a little anthology of commits we can find in the git tree:
> git log -i -E --grep='fix (\w* )?build' --oneline | wc -l
> 1364 occurrences
> git log -E --grep='auto sipify' --oneline  | wc -l
> 763
> git log -i -E --grep="Apply suggestions? from (code review|@)" --oneline |
> wc -l
> 223
> git log -i -E --grep="add?ress (review )?comments?" --oneline | wc -l
> 65
> git log -i -E --grep="^fix typos?" --oneline | wc -l
> 387
> git log -i -E --grep="make (\w* )?happy" --oneline | wc -l
> 47  // QGIS developers are like that, we like to make people happy
> So, now that I have presented cases where I think we would benefit
> from a more linear history, how do we reduce the noise to signal ratio
> in our git history? I think we should tend towards atomic commits.
> What is an atomic commit? Qt's wiki defines an atomic commit as a
> "commit that should contain exactly one self-contained change." [0]
> A self-contained change is itself not really defined in Qt's wiki, but
> to me a self-contained change should provide at least:
> * Buildable, and working
> * All tests are passing
> * Does not mix unrelated changes
> The only point at which all these conditions are guaranteed to be met
> would be on a squash of an approved and passing ci PR. Now I can also
> see value in having multiple commits per PR, for example if in the end
> you squashed your PR into two commits, i.e: one for the feature and
> one for the tests that would make two atomic commits too.
> In an ideal world developers would write code right on the first try
> but in reality it's a much more organic process. So I would suggest
> this simple policy:
> * By default squash a PR before merging into master
> * IF and only if the contributor specifically asks for their branch to
> be merged, merge as is
> And abide by a few rules like:
> * Always separate refactors from features into two separate PRs. ( Yes
> that would probably mean slightly more PRs from core devs, but also
> smaller, easier, and faster to review  PRs)
> * We could introduce a commit message guideline [0] but this is to be
> discussed
> I think this way we could achieve a more linear, and more importantly
> a more human readable history.
> Any thoughts on this ? It's still early on but depending on the
> outcome of the discussion I will create a QEP similar to QEP 314 but
> for commit guidelines.
> Cheers,
> Valentin
> [0] https://wiki.qt.io/Commit_Policy
> [1] https://tbaggery.com/2008/04/19/a-note-about-git-commit-messages.html
> Finally here are a few references from other open source projects I
> used to write this mail:  Godot, Qt, and Blender
> https://contributing.godotengine.org/en/latest/pull_requests/pull_request_guidelines.html#contribute-one-change-at-a-time
> https://developer.blender.org/docs/handbook/contributing/review_playbook/
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260828/e5c966a2/attachment-0001.htm>
More information about the QGIS-Developer mailing list
