[QGIS-Developer] QGIS 3.40 build failure in crssync with PROJ 9.7.1 on OSGeo4W
Mehmet DUMAN (UZAY)
mehmet.duman at tubitak.gov.tr
Wed Feb 4 13:15:29 PST 2026
Hello QGIS developers,
I am building QGIS 3.40 (ltr) from source on Windows using the OSGeo4W development environment and Visual Studio 2022, and I am encountering a build failure in the "synccrsdb" target.
Environment
- QGIS: 3.40 (source build)
- OS: Windows x64
- Compiler: Visual Studio 2022
- Build system: CMake (MSVC generator)
OSGeo4W packages installed
Main development meta-package:
qgis-ltr-deps
Relevant dependency versions:
proj-runtime: 9.7.1
proj-data: 1.24
Error
The build fails while running "crssync.exe":
Operation needs translation in QgsCoordinateReferenceSystemUtils::translateProjection: spilhaus
aborted
Visual Studio reports:
synccrsdb.vcxproj
custom build exited with code -1073740791
Question
Is QGIS 3.40 expected to build correctly with PROJ 9.7.x, or is there a recommended PROJ version range for this release when using OSGeo4W?
Should the qgis-ltr-deps package alone be sufficient to build the QGIS LTR source on Windows?
If not, what is the recommended dependency set or workflow for building the LTR branch with OSGeo4W?
Best regards,
Mehmet Duman
R&D Engineer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260205/b54ff5bc/attachment.htm>
